Possible for extension to withhold number?
Discussion in '3CX Phone System - General' started by nell1000, Jul 29, 2013.
  1. nell1000
    Jan 4, 2013
    9
    May be glaringly obvious but none of my searches have returned any answers.
    Have a request from an end user asking if some of their users/extensions can have the ability to withhold the outgoing number when they choose. Ive had a look through the settings but cannot see where/if this can be configured.
    Any ideas?
    Thanks,
    Nell
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    Go to setting, advanced and then dial codes and look at the last entry for block outbound caller ID. Hover your cursor over the ? for details on how to do. I think this is what you are asking about.
  3. leejor
    11,117
    329
    It may depend on the type of outgoing trunks you are using.
  4. nell1000
    Jan 4, 2013
    9
    Thanks lneblett... staring me in the face.
    Trunk is VOIPTALK, will checkout on site tomorrow.
