Possible HACK
Discussion in '3CX Phone System - General' started by patrickrivard, Oct 6, 2015.
  1. patrickrivard
    patrickrivard New Member
    May 29, 2008
    100
    Can anyone shed some light on this LOG file?
    It appears that someone is trying to HACK into our 3CX server, but I have no clue on how to proceed to resolve this issue...
    I have blocked a bunch of IP in the IP Black List of the Security Tab in the Management console, but aside of that what can be done???
    In the following LOG, I have replaced our External IP with XXX.XXX.XXX.XXX, but the rest is all original but also unknown IP...
    04-Oct-2015 22:39:54.479 [CM102001]: Authentication failed for AuthFail Recv Req INVITE from 195.154.207.24:52952 tid=aa44cd2b-e835-472b-a04d-be340961e392 Call-ID=dyegrwcbqwbdwgmnjpvoartwddxfbtwybkomxlwdiexjlrsdvw:
    INVITE sip:00016468443955@XXX.XXX.XXX.XXX SIP/2.0
    Via: SIP/2.0/UDP 195.154.207.24:52952;branch=z9hG4bKaa44cd2b-e835-472b-a04d-be340961e392;rport=52952
    Max-Forwards: 70
    Contact: <sip:c@195.154.207.24:52952>
    To: <sip:00016468443955@XXX.XXX.XXX.XXX>
    Call-ID: dyegrwcbqwbdwgmnjpvoartwddxfbtwybkomxlwdiexjlrsdvw
    CSeq: 2 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    Content-Type: application/sdp
    Proxy-Authorization: Digest username="c",realm="3CXPhoneSystem",nonce="414d535c0c2273fa31:d21c96184c423d3efac7afba94e4693d",response="91f25bd9114132cae55e2063bfd9e37d",uri="sip:00016468443955@XXX.XXX.XXX.XXX",algorithm=MD5
    User-Agent: Ozeki VoIP SIP SDK v10.1.13
    Content-Length: 392
    v=0
    o=- 302631338 302631338 IN IP4 195.154.207.24
    s=Ozeki VoIP SIP SDK v10.1.13
    c=IN IP4 195.154.207.24
    t=0 0
    m=audio 52948 RTP/AVP 18 8 0 3 100
    a=rtpmap:18 G729/8000
    a=fmtp:18 annexb=no
    a=rtpmap:8 PCMA/8000
    a=rtpmap:0 PCMU/8000
    a=rtpmap:3 GSM/8000
    a=rtpmap:100 SPEEX/16000
    a=sendrecv
    m=video 52945 RTP/AVP 99
    a=rtpmap:99 H264/90000
    a=fmtp:99 packetization-mode=1
    a=sendrecv
    ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    04-Oct-2015 22:39:54.479 [CM302002]: Authentication failed due to unidentified source of: SipReq: INVITE 00016468443955@XXX.XXX.XXX.XXX tid=aa44cd2b-e835-472b-a04d-be340961e392 cseq=INVITE contact=c@195.154.207.24:52952 / 2 from(wire)
    04-Oct-2015 22:39:52.439 [CM102001]: Authentication failed for AuthFail Recv Req INVITE from 195.154.207.24:52952 tid=03e66996-95c3-4d1d-a33b-3d8448e9bcf8 Call-ID=hedjlenchiykjwgwvwmxdetjajggjnfxgbfvumhrvmcoicpelv:
    INVITE sip:90016468443955@XXX.XXX.XXX.XXX SIP/2.0
    Via: SIP/2.0/UDP 195.154.207.24:52952;branch=z9hG4bK03e66996-95c3-4d1d-a33b-3d8448e9bcf8;rport=52952
    Max-Forwards: 70
    To: <sip:90016468443955@XXX.XXX.XXX.XXX>
    Call-ID: hedjlenchiykjwgwvwmxdetjajggjnfxgbfvumhrvmcoicpelv
    CSeq: 2 INVITE
    Proxy-Authorization: Digest username="c",realm="3CXPhoneSystem",nonce="414d535c0c2273f886:23f4ef11b001a6f092e318147f90977b",response="bdd2ac799ceba6784ff9948da11fa31f",uri="sip:90016468443955@XXX.XXX.XXX.XXX",algorithm=MD5
    Content-Length: 394
    v=0
    o=- 1133145147 1133145147 IN IP4 195.154.207.24
    t=0 0
    m=audio 52942 RTP/AVP 18 8 0 3 100
    a=fmtp:18 annexb=no
    a=rtpmap:3 GSM/8000
    a=sendrecv
    m=video 52959 RTP/AVP 99
    a=sendrecv
    04-Oct-2015 22:39:52.439 [CM302002]: Authentication failed due to unidentified source of: SipReq: INVITE 90016468443955@XXX.XXX.XXX.XXX tid=03e66996-95c3-4d1d-a33b-3d8448e9bcf8 cseq=INVITE contact=c@195.154.207.24:52952 / 2 from(wire)
    04-Oct-2015 22:39:50.352 [CM102001]: Authentication failed for AuthFail Recv Req INVITE from 195.154.207.24:52952 tid=21e24306-fbcd-46d8-b059-71e3840a8528 Call-ID=wseuheoeafvyvuvwqyydiuqyiacqhxwhybnluoaaeaepnpbhdk:
    INVITE sip:+16468443955@XXX.XXX.XXX.XXX SIP/2.0
    Via: SIP/2.0/UDP 195.154.207.24:52952;branch=z9hG4bK21e24306-fbcd-46d8-b059-71e3840a8528;rport=52952
    Max-Forwards: 70
    To: <sip:+16468443955@XXX.XXX.XXX.XXX>
    Call-ID: wseuheoeafvyvuvwqyydiuqyiacqhxwhybnluoaaeaepnpbhdk
    CSeq: 2 INVITE
    Proxy-Authorization: Digest username="c",realm="3CXPhoneSystem",nonce="414d535c0c2273f646:18250ced975f8cc8b47a11e1c6d88564",response="8457e4daf92adaabfb89d63651879f8c",uri="sip:+16468443955@XXX.XXX.XXX.XXX",algorithm=MD5
    Content-Length: 394
    v=0
    o=- 1592679041 1592679041 IN IP4 195.154.207.24
    t=0 0
    m=audio 52962 RTP/AVP 18 8 0 3 100
    a=fmtp:18 annexb=no
    a=rtpmap:3 GSM/8000
    a=sendrecv
    m=video 52966 RTP/AVP 99
    a=sendrecv
    04-Oct-2015 22:39:50.351 [CM302002]: Authentication failed due to unidentified source of: SipReq: INVITE +16468443955@XXX.XXX.XXX.XXX tid=21e24306-fbcd-46d8-b059-71e3840a8528 cseq=INVITE contact=c@195.154.207.24:52952 / 2 from(wire)
    04-Oct-2015 22:39:48.317 [CM102001]: Authentication failed for AuthFail Recv Req INVITE from 195.154.207.24:52952 tid=d54608d7-ea2b-4c84-8fe1-f567134b93c0 Call-ID=scoacueynfrhkhjfahpwxgcxtsmovesvsiifmynhpfpgcbwvjt:
    INVITE sip:16468443955@XXX.XXX.XXX.XXX SIP/2.0
    Via: SIP/2.0/UDP 195.154.207.24:52952;branch=z9hG4bKd54608d7-ea2b-4c84-8fe1-f567134b93c0;rport=52952
    Max-Forwards: 70
    To: <sip:16468443955@XXX.XXX.XXX.XXX>
    Call-ID: scoacueynfrhkhjfahpwxgcxtsmovesvsiifmynhpfpgcbwvjt
    CSeq: 2 INVITE
    Proxy-Authorization: Digest username="c",realm="3CXPhoneSystem",nonce="414d535c0c2273f401:48d3216639ff9697c8de19468589f552",response="96d7299241ca77015b69c38f01c2411a",uri="sip:16468443955@XXX.XXX.XXX.XXX",algorithm=MD5
    Content-Length: 394
    v=0
    o=- 1217459954 1217459954 IN IP4 195.154.207.24
    t=0 0
    m=audio 52965 RTP/AVP 18 8 0 3 100
    a=fmtp:18 annexb=no
    a=rtpmap:3 GSM/8000
    a=sendrecv
    m=video 52942 RTP/AVP 99
    a=sendrecv
    04-Oct-2015 22:39:48.316 [CM302002]: Authentication failed due to unidentified source of: SipReq: INVITE 16468443955@XXX.XXX.XXX.XXX tid=d54608d7-ea2b-4c84-8fe1-f567134b93c0 cseq=INVITE contact=c@195.154.207.24:52952 / 2 from(wire)
    04-Oct-2015 22:39:46.284 [CM102001]: Authentication failed for AuthFail Recv Req INVITE from 195.154.207.24:52952 tid=ae8d4597-dbe3-4970-8a4d-30d4a8e500bb Call-ID=gcgtdhqotuuxmjlrfkbhettbkeikppguamadedvssmkxwssarj:
    INVITE sip:0016468443955@XXX.XXX.XXX.XXX SIP/2.0
    Via: SIP/2.0/UDP 195.154.207.24:52952;branch=z9hG4bKae8d4597-dbe3-4970-8a4d-30d4a8e500bb;rport=52952
    Max-Forwards: 70
    To: <sip:0016468443955@XXX.XXX.XXX.XXX>
    Call-ID: gcgtdhqotuuxmjlrfkbhettbkeikppguamadedvssmkxwssarj
    CSeq: 2 INVITE
    Proxy-Authorization: Digest username="c",realm="3CXPhoneSystem",nonce="414d535c0c2273f291:ba889dfc74c3d9815cc895a406d0dfaf",response="9a918c1ecdeb3c5bece5d6ab1389380d",uri="sip:0016468443955@XXX.XXX.XXX.XXX",algorithm=MD5
    Content-Length: 392
    v=0
    o=- 265493167 265493167 IN IP4 195.154.207.24
    t=0 0
    m=audio 52945 RTP/AVP 18 8 0 3 100
    a=fmtp:18 annexb=no
    a=rtpmap:3 GSM/8000
    a=sendrecv
    m=video 52957 RTP/AVP 99
    a=sendrecv
    04-Oct-2015 22:39:46.284 [CM302002]: Authentication failed due to unidentified source of: SipReq: INVITE 0016468443955@XXX.XXX.XXX.XXX tid=ae8d4597-dbe3-4970-8a4d-30d4a8e500bb cseq=INVITE contact=c@195.154.207.24:52952 / 2 from(wire)
    04-Oct-2015 22:39:44.248 [CM102001]: Authentication failed for AuthFail Recv Req INVITE from 195.154.207.24:52952 tid=132cf456-898a-4294-86ba-7e9c9fe40a68 Call-ID=wktaooxvnsdwybaimvjsbbuhfguswetisbvkamrucgsiaryvdv:
    INVITE sip:01116468443955@XXX.XXX.XXX.XXX SIP/2.0
    Via: SIP/2.0/UDP 195.154.207.24:52952;branch=z9hG4bK132cf456-898a-4294-86ba-7e9c9fe40a68;rport=52952
    Max-Forwards: 70
    To: <sip:01116468443955@XXX.XXX.XXX.XXX>
    Call-ID: wktaooxvnsdwybaimvjsbbuhfguswetisbvkamrucgsiaryvdv
    CSeq: 2 INVITE
    Proxy-Authorization: Digest username="c",realm="3CXPhoneSystem",nonce="414d535c0c2273f060:adf77f7388e608f7b9211400e9de689a",response="5be94ca4773034b0714844b5f980846f",uri="sip:01116468443955@XXX.XXX.XXX.XXX",algorithm=MD5
    Content-Length: 392
    v=0
    o=- 954803414 954803414 IN IP4 195.154.207.24
    t=0 0
    m=audio 52966 RTP/AVP 18 8 0 3 100
    a=fmtp:18 annexb=no
    a=rtpmap:3 GSM/8000
    a=sendrecv
    m=video 52961 RTP/AVP 99
    a=sendrecv
    04-Oct-2015 22:39:44.247 [CM302002]: Authentication failed due to unidentified source of: SipReq: INVITE 01116468443955@XXX.XXX.XXX.XXX tid=132cf456-898a-4294-86ba-7e9c9fe40a68 cseq=INVITE contact=c@195.154.207.24:52952 / 2 from(wire)
    04-Oct-2015 22:39:42.240 [CM102001]: Authentication failed for AuthFail Recv Req INVITE from 195.154.207.24:52952 tid=abf7241b-7781-4e48-af4b-1042edc2fb11 Call-ID=yseplxntsstakstbwmrpodjowuvbvvqdhrejkphlwnfyulxwob:
    INVITE sip:901116468443955@XXX.XXX.XXX.XXX SIP/2.0
    Via: SIP/2.0/UDP 195.154.207.24:52952;branch=z9hG4bKabf7241b-7781-4e48-af4b-1042edc2fb11;rport=52952
    Max-Forwards: 70
    To: <sip:901116468443955@XXX.XXX.XXX.XXX>
    Call-ID: yseplxntsstakstbwmrpodjowuvbvvqdhrejkphlwnfyulxwob
    CSeq: 2 INVITE
    Proxy-Authorization: Digest username="c",realm="3CXPhoneSystem",nonce="414d535c0c2273ee67:289a31ac641c8400f78215aab2742d92",response="76224d166d8243c39d2f18ed8b95f2bd",uri="sip:901116468443955@XXX.XXX.XXX.XXX",algorithm=MD5
    Content-Length: 392
    v=0
    o=- 649468010 649468010 IN IP4 195.154.207.24
    t=0 0
    m=audio 52954 RTP/AVP 18 8 0 3 100
    a=fmtp:18 annexb=no
    a=rtpmap:3 GSM/8000
    a=sendrecv
    a=sendrecv
    04-Oct-2015 22:39:42.240 [CM302002]: Authentication failed due to unidentified source of: SipReq: INVITE 901116468443955@XXX.XXX.XXX.XXX tid=abf7241b-7781-4e48-af4b-1042edc2fb11 cseq=INVITE contact=c@195.154.207.24:52952 / 2 from(wire)
    04-Oct-2015 22:39:40.121 [CM102001]: Authentication failed for AuthFail Recv Req INVITE from 195.154.207.24:52952 tid=17471c90-e1f0-4d2d-ad2e-a81ad52054cc Call-ID=xavbvmqtnlmktsdligdayjtctrgihlosrqsvjopiilvxowxtla:
    INVITE sip:916468443955@XXX.XXX.XXX.XXX SIP/2.0
    Via: SIP/2.0/UDP 195.154.207.24:52952;branch=z9hG4bK17471c90-e1f0-4d2d-ad2e-a81ad52054cc;rport=52952
    Max-Forwards: 70
    To: <sip:916468443955@XXX.XXX.XXX.XXX>
    Call-ID: xavbvmqtnlmktsdligdayjtctrgihlosrqsvjopiilvxowxtla
    CSeq: 2 INVITE
    Proxy-Authorization: Digest username="c",realm="3CXPhoneSystem",nonce="414d535c0c2273eb18:422704f5be36b6b32ab6dee2a49344c8",response="ad2c8ce2ea3ec47072fa867ac2c99813",uri="sip:916468443955@XXX.XXX.XXX.XXX",algorithm=MD5
    Content-Length: 394
    v=0
    o=- 1880510428 1880510428 IN IP4 195.154.207.24
    t=0 0
    a=fmtp:18 annexb=no
    a=rtpmap:3 GSM/8000
    a=sendrecv
    m=video 52946 RTP/AVP 99
    a=sendrecv
    04-Oct-2015 22:39:40.121 [CM302002]: Authentication failed due to unidentified source of: SipReq: INVITE 916468443955@XXX.XXX.XXX.XXX tid=17471c90-e1f0-4d2d-ad2e-a81ad52054cc cseq=INVITE contact=c@195.154.207.24:52952 / 2 from(wire)
    04-Oct-2015 21:36:46.827 PBX has dropped a message with 'User-Agent: friendly-scanner' from IP 5.189.163.147 because it is on blocked UAs list
  2. swink
    Oct 9, 2014
    15
    Turn down the number of failures required to be banned and turn up the length of time they are banned. Not much to do assuming you are using strong passwords. They will run out of patience and IP address space long before they get in.
  3. 12494
    12494 Member
    Apr 16, 2010
    306
    31
    Can you just whitelist (only allow) your SIP provider in your firewall for port 5060?
    Allen
  4. patrickrivard
    May 29, 2008
    100
    @ SWINK; I have performed the suggested mod to the default settings... Let's see if it'll help... Thanks
    @ 12494; Allen, This is a really good idea. I will try to find out how to implement in our Firewall and see if this also helps...
    These were good and constructive comments. It is really appreciated.
    Any other comments/advice or solutions are welcome!
    I will try to keep this post updated with our results...
    Thank you
