Possible problems with SPA3102 on 7.1
Discussion in '3CX Phone System - General' started by boffin, Mar 18, 2009.
  1. boffin
    Jun 25, 2008
    24
    I note that the SPA3102 gateway has been re-written for v7.1 and think this might be the reason for my problems.
    I have just configured a new 3CX server on v7.1 in an identical way as an earlier v7.0, with a Linksys SPA3102 providing a PSTN Gateway.
    Using an identical configuration as on the SPA3102 as I had historically used, I was unable to get incoming calls to even register in the 3CX system. To confirm that I wasn't going silly, I even swapped a SPA3102 from the 7.0 system to the 7.1.
    What I eventually found in the SPA3102 configuration, I had to set the PSTN Answer Delay: to either 0 or 1 to allow incoming calls to register. Any higher and it wouldn't work. The downside to this is that CID no longer works, as it need a setting of at least 2 to give the system long enough to extract this data.
    Also another unearthed couple smaller faults. When you create a new SPA3102 gateway, the 3CX defaults to port 5062. This is not open, even when the configuration is saved, but port 5061 is. I had to manually reset the port to 5061 on the 3CX to make it work. (setting both 3CX and SPA3102 to 5062 isn't any good. Also I noted that the generated config file, still persists in using port 5062 - even though its been set to 5061 on the 3CX
    Can anyone else confirm my findings? Can an update be provided soon Please!
    So in summary, with a little manual tweaking, I now have incoming calls from the PSTN, but no CID being delivered.
    John
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    Issue noted on the PSTN answer delay. We are setting this to '0' by default in the current template. What value were you finding on yours after you provision? What country and telco are you using? This may need to vary per tone set to get it right.
    Also, the Linksys port is set to 5062 on the line port since the phone port uses 5060. The 3CX install uses 5061 for Secure SIP, hence the reason for it being open. Are you encountering issues due to a firewall running on the 3CX machine?
    Await you reply to review templating possibilities.
  3. boffin
    Jun 25, 2008
    24
    Thanks for the comment William.
    I am manually configuring the SPA3102. However I checked the template generated, and this is 0
    I am in New Zealand, and tried both Custom (but nothing configurable) and our close cousins Australia (which it is currently set to). I have found that I have needed historically to set the delay to at least 2, to allow for the CID information to be transferred to the phone. As stated, if set to 2 or higher, the incoming call isn't delivered to the phone system at all.
    I currently have the Extension on port 5060 and the PSTN on 5061 and its all working. I have tried 5060 and 5062, but PSTN would not register. Device in on local LAN and Windows firewall is disabled. Even tried to telnet to the 3CX server, using port 5062 and was told that the port was not open but without any changes on the 3CX, I tried port 5061 and it was open.
  4. boffin
    Jun 25, 2008
    24
    After more experimenting, I have found that if I set the delay to 3, I get the following error in the log file
    22:32:20.562 [CM102001]: Authentication failed for SipReq: INVITE <10000@192.168.3.4 tid=-9f7077e5 cseq=INVITE contact=33594053@192.168.3.5:5061 / 102 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    22:32:20.562 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:%3C10000@192.168.3.4 SIP/2.0
    Via: SIP/2.0/UDP 192.168.3.5:5061;branch=z9hG4bK-9f7077e5
    Max-Forwards: 70
    Contact: "Ferry PSTN"<sip:33594053@192.168.3.5:5061>
    To: <sip:%3C10000@192.168.3.4>
    From: "Ferry PSTN"<sip:33594053@192.168.3.4>;tag=4ab42041a72eb25o1
    Call-ID: c1e9eb71-366c19b5@192.168.3.5
    CSeq: 102 INVITE
    Expires: 240
    Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
    Proxy-Authorization: Digest username="10000",realm="3CXPhoneSystem",nonce="414d535bffd2a22465:af7032d330065eb3dc1f033c90da6ad3",uri="sip:<10000@192.168.3.4",algorithm=MD5,response="223e223e1831c94bd59b71b7d42f9501"
    Supported: x-sipura, replaces
    User-Agent: Linksys/SPA3102-5.1.7(GW)
    Content-Length: 0
    Remote-Party-ID: Ferry PSTN <sip:33594053@192.168.3.4>;screen=yes;party=calling
    22:32:20.562 [CM302002]: Authentication failed due to unidentified source of: SipReq: INVITE <10000@192.168.3.4 tid=-9f7077e5 cseq=INVITE contact=33594053@192.168.3.5:5061 / 102 from(wire)
    22:32:20.453 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    Via: SIP/2.0/UDP 192.168.3.5:5061;branch=z9hG4bK-605c5e85
    Max-Forwards: 70
    CSeq: 101 INVITE
    Expires: 240
    Content-Length: 0
    22:32:20.453 [CM302001]: Authorization system can not identify source of: SipReq: INVITE <10000@192.168.3.4 tid=-605c5e85 cseq=INVITE contact=33594053@192.168.3.5:5061 / 101 from(wire)
    Ext 51 doesn't ring
    However if I set the delay to 1 then the following appears in the logs
    22:36:35.109 [CM505001]: Ext.51: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-6.1.3(a)] Transport: [sip:192.168.3.4:5060]
    22:36:35.093 [CM503002]: Call(87): Alerting sip:51@192.168.38.81:5060
    22:36:34.921 [CM503004]: Call(87): Calling: Ext:Ext.51@[Dev:sip:51@192.168.38.81:5060]
    22:36:34.921 [CM503010]: Making route(s) to <sip:51@192.168.3.4:5060>
    22:36:34.921 [CM505002]: Gateway:[Ferry PSTN] Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.7(GW)] Transport: [sip:192.168.3.4:5060]
    22:36:34.906 [CM503001]: Call(87): Incoming call from 10000@(Ln.10000@Ferry PSTN) to <sip:51@192.168.3.4:5060>
    Strange, but true
    and call is delivered to Ext 51
  5. Bob Denny
    Bob Denny New Member
    Feb 21, 2009
    131
    I have this exact same problem. Logs are similar. Any ideas? I am in the US. The problem appears to be related to whether the CID is picked up by the 3102. If it is, 3CX refuses the call:
    Code:
    15:03:22.583  [CM102001]: Authentication failed for SipReq:  INVITE 4803969700@192.168.2.20 tid=-c88aca68 cseq=INVITE contact=4808072310@192.168.2.101:5063 / 102 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    15:03:22.583  [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
      INVITE sip:4803969700@192.168.2.20 SIP/2.0
      Via: SIP/2.0/UDP 192.168.2.101:5063;branch=z9hG4bK-c88aca68
      Max-Forwards: 70
      Contact: "10002"<sip:4808072310@192.168.2.101:5063>
      To: <sip:4803969700@192.168.2.20>
      From: "STEPHENS S"<sip:4808072310@192.168.2.20>;tag=fe6f71ccbab96a6co1
      Call-ID: 59fa0d4c-bf8384ec@192.168.2.101
      CSeq: 102 INVITE
      Expires: 240
      Proxy-Authorization: Digest username="10002",realm="3CXPhoneSystem",nonce="414d535c0040beaa18:780b5f0259bbfdf6b3445542de93a69e",uri="sip:4803969700@192.168.2.20",algorithm=MD5,response="5d1ad8e39bc9b92ab5988bb1eb4a8808"
      Content-Length: 0
      Remote-Party-ID: STEPHENS S      <sip:4808072310@192.168.2.20>;screen=yes;party=calling
    15:03:22.583  [CM302002]: Authentication failed due to unidentified source of: SipReq:  INVITE 4803969700@192.168.2.20 tid=-c88aca68 cseq=INVITE contact=4808072310@192.168.2.101:5063 / 102 from(wire)
    15:03:22.474  [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
      Via: SIP/2.0/UDP 192.168.2.101:5063;branch=z9hG4bK-d51f696c
      Max-Forwards: 70
      CSeq: 101 INVITE
      Expires: 240
      Content-Length: 0
    15:03:22.474  [CM302001]: Authorization system can not identify source of: SipReq:  INVITE 4803969700@192.168.2.20 tid=-d51f696c cseq=INVITE contact=4808072310@192.168.2.101:5063 / 101 from(wire)
    With the 3102 set to answer after 0 rings, and no other changes!!:
    Code:
    14:52:39.177  [CM503008]: Call(64): Call is terminated
    14:52:39.162  [CM503008]: Call(64): Call is terminated
    14:52:26.958  [CM503004]: Call(64): Calling: Ext:Ext.103@[Dev:sip:103@192.168.2.100:5060]
    14:52:26.958  [CM503010]: Making route(s) to <sip:103@127.0.0.1:5060>
    14:52:16.958  [CM503007]: Call(64): Device joined: sip:800@127.0.0.1:40600;rinstance=9d5f0749e218ea9c
    14:52:16.943  [CM503007]: Call(64): Device joined: sip:10002@192.168.2.101:5063
    14:52:16.927  [CM505001]: Ext.800: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] Transport: [sip:127.0.0.1:5060]
    14:52:16.896  [CM503002]: Call(64): Alerting sip:800@127.0.0.1:40600;rinstance=9d5f0749e218ea9c
    14:52:16.412  [CM503004]: Call(64): Calling: Ext:Ext.800@[Dev:sip:800@127.0.0.1:40600;rinstance=9d5f0749e218ea9c]
    14:52:16.412  [CM503010]: Making route(s) to <sip:800@X.X.X.X:5060>
    14:52:16.396  [CM505002]: Gateway:[Bob's land line] Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.7(GW)] Transport: [sip:192.168.2.20:5060]
    14:52:16.380  [CM503001]: Call(64): Incoming call from 10002@(Ln.10002@Bob's land line) to <sip:800@X.X.X.X:5060>
    14:52:16.380  [CM503012]: Inbound office hours rule (unnamed) for 10002 forwards to DN:800
    I tried adding a DID rule but that didn't do it. What now?
  6. Bob Denny
    Feb 21, 2009
    131
    I solved this one! I needed to add a Source Identification rule to allow it to ID the port by the Contact : Host Part with my SPA3102's IP/Port in it (192.168.2.101:5063). The error messages are pretty obscure, but I tried this on a whim and it worked.
    Would there be a better/preferable way to ID it?
  7. boffin
    Jun 25, 2008
    24
    Thanks for the feedback, however I don't fully understand the solution
    Bob ( or anyone else), can you explain in simple terms the solution please
    John
  8. Bob Denny
    Feb 21, 2009
    131
    Under PSTN Devices, select the gateway for your SPA3102. Then click the Inbound Parameters tab. In the Call Source Identification area, SIP Field, select Contact : Host Part. For Variable, enter the IP:port of your SPA3102, for example 192.168.2.101:5063.
