possible v11 bug - please read me!
Discussion in '3CX Phone System - General' started by craigreilly, May 30, 2012.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,321
    253
    Ring Group set to ring all at the same time. A group of 10 extensions.
    1 of the extensions has "Ring My Mobile At The Same Time" enabled.
    With that enabled - all all phones in the ring group ring once, then the system tries only the External Mobile device. It took a while to figure out what was going on. Why are the phones only ringing once, but the caller is still getting ring tones?
    Finally saw a mobile number in the trunk outbound calls - matched it to my phone list and figured it out.
    Can anyone else confirm this occurance in v11?
    10,758
    286
    How is the call going out to the mobile? In most cases, a call going out on just about anything but a VoIP provider (yes, there can be exceptions depending on the gateway and how your provider operates), will be considered answered just after the digits are sent to the gateway. That is probably what is happening in your case. 3CX thinks that the mobile has answered (answer message from the gateway) and ceases ringing the other extensions.
    If you were doing testing using the VoIP provider previously, and are now sending the call out over the Patton, that may be the reason.
    Try creating an outbound rule for that one mobile number that sends it out over the VoIP provider trunk. Place it ahead of the "general" rule.
  3. craigreilly
    Feb 1, 2012
    3,321
    253
    I'll give it a shot tomorrow.. Thanks.
  4. craigreilly
    Feb 1, 2012
    3,321
    253
    Leejor - that is it exactly. The Patton is getting the call.
    I guess a feature request or option - to ignore the "ring deks and mobile at same time" for Ring Groups is in order.
  5. leejor
    10,758
    286
    I think, what it comes down to..is , if you wish to use that feature, then you have to be using trunks that are able to provide answer supervision when the mobile actually answers, not before.
    If the VoIP trunk you are currently using, is going to remain, then leave the rule for that mobile in place. Any calls to it will try to use the VoIP trunk if it is idle, and the call will work the way you want it to. If the trunks is in use, the call to all others in the ring-group should continue to ring until answered. The mobile will not be rung.
