possiblity to 3cx assistant to make attended transfert
Discussion in '3CX Phone System - General' started by bluetel2, Mar 30, 2010.
  1. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    Hi all,
    is it possible with last 3cx assistant to make attended transfert ?
    tks advance
  2. roberts3cx
    Feb 11, 2010
    This information would be interesting for us too.
  3. stober
    Jun 19, 2010
    14
    hum, dont remember seeing that feature specifically.
    Because the dig.recep is a "special" extension (default 8000) you could setup a regular extension that is call forwarded to the dig.recep.
    Add the new regular reception extension to a group call "Attendant" and voila, drag and drop calls to the dig.recep!
    stober
  4. carolinainnovative
    May 4, 2009
    369
    6
    I think he meant attended transfer - not attendant transfer... as in I stay on the line, talk to the person, "hey its so and so on the phone for you. ok here they are." and then transfer. Unfortunately, either way, I think the answer is no. There are workarounds you could use to simulate the behavior - but the assistant itself does not support attended transfers otherwise.
  5. stober
    Jun 19, 2010
    14
    haha. that would be a nice feature.
