post hangup destination on queues
Discussion in 'Ideas' started by tratz, May 23, 2016.
post hangup destination on queues 4.9 5 18votes
4.9/5, 18 votes
  1. tratz
    tratz New Member
    Oct 21, 2015
    111
    16
    It would be nice to have a post hangup destination setup on queues. We are looking to rollout a survey to our customers after speaking in a queue and would rather have the system automatically send the call to the survey versus reminding the staff to hit a BLF key or have the agent send the call to the survey.
    uit likes this.
  2. uptime1
    uptime1 New Member
    Jan 13, 2012
    112
    31
  3. SECOIT GmbH
    Apr 3, 2017
    66
    25
    So many call flow features but that's missing to allow to do "something" with the call after the agent hung up.
    +1
  4. fredy.martinez
    Jun 29, 2016
    8
    By programming concept every sequence must have a start and reach an end, if not the programming would stop being structured as happens in this case, where the flow of the call never reaches the end, but its end occurs once the call Is transferred to any destination (queue, extension). This emphatically limits the possibilities of process control for us developers (reminds me of old times with basic language).
  5. interact1
    Sep 5, 2016
    11
    +1 for this feature
  6. Trestill
    Jan 22, 2015
    48
    and another upvote
  7. voiphorizon
    Feb 23, 2016
    26
    6
    and another upvote
  8. Felim
    Oct 9, 2017
    Plus one vote
    it could be a wrap up code
    *99 to send a survey
    *98 to record that the call was a customer order
    *97 a technical query
  9. Tim Milan
    Sep 22, 2017
    6
    +1 Vote for this, exactly what my company is looking for
  10. justint
    May 6, 2011
  11. Denisas
    Jan 15, 2018
  12. Mekaeil Andisheh
    Apr 8, 2018
    15
  13. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    891
    156
    I don't see how that would be possible if either party hangs up. Remember 3CX is a SIP complaint phone system. If a phone hangs up, that's going to send a Bye to 3CX and the call will be dropped. I've put considerable thought to this question specifically because we have a Post Call Survey add-on for 3CX, and I would love the ability for the agent to hang up and have the call automatically transfer to a survey (CFD) extension. I just don't think this is possible with 3CX.
    I see a couple of ways that you could automate this process. tratz has already mentioned the BLF to CFD option. With our survey add-on we provide a web portal that the agent uses to select a survey from a list of surveys. When the agent selects the survey, the active call is immediately transferred to the correct extension, and the agent is free to take the next call. If you have a customizable CRM, you could do much the same thing using our HTTP API.
    I simply don't believe it is possible (today) to have the agent hang up and have the call automatically transferred to an extension. The call will be dropped the instant the agent hangs up.
  14. Mekaeil Andisheh
    Apr 8, 2018
    15
    I have an idea for survey but that is not great,
    with CFD i could design the survey and register rating in my website.
    But we need an action with CFD after Transfer Call user forward to this component.
    can we create new Extension for Survey Component and after end of call, forward user to Survey component ?
    i think about it if this action would be possible, the call center after call, will transfer user to Survey.
    OleAndreas likes this.
  15. Gunes Erdemi
    May 11, 2018
  16. Mojtaba.D
    Oct 18, 2018
    Upvote for this feature
  17. voiptoys
    Feb 13, 2013
    891
    156
    As an update, we have modified our survey tool. An inbound call is sent to a CFD that asks if the caller would be agreeable to receiving a phone call after their call has completed. If yes, we flag them for a call back after the call, then we monitor the calls for the disconnect. When the call is completed, we immediately call them back at the requested phone number. That's as close as you can get with 3CX.
  18. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    Would be nice if the CFD could process a command and wait - even on a transferred call. Like camp out during the agents call.
    1) Incoming call to CFD
    2) CFD Transfers the call to agent and "WAITS"
    3) Upon disconnect, flow continues.
    Seems like right now the CFD Transfers the call and thats it. Game over.
  19. voiptoys
    Feb 13, 2013
    891
    156
    There is an "on disconnect" event you can capture, but that's an immediate event. You are right, the CFD doesn't have the ability to follow the call once it has been transferred from the CFD. But in this case, that wouldn't help because the caller has disconnected and there is no way to ignore the "bye" and transfer the call to the survey. The only options are to either (1) have the agent transfer the call to the survey, or (2) call the back. I don't see any other options.
  20. south14
    May 15, 2015
    8
