Post Install addition of an SSL cert exported from IIS in V15
Discussion in '3CX Phone System - General' started by gwinn, May 15, 2017.
  1. gwinn
    Oct 4, 2007
    Hi All
    I have got a UCC certificate for my web and exchange servers and wanted to use it on my 3CX installation.
    3CX is currently using a self signed 3CX SSL cert and Edge etc are throwing up warnings about the cert signer not being recognised.
    I would like to use my UCC SSL cert from my exchange and IIS server on 3CX. The public names all resolve correctly to the server that 3CX is on so no issues there. My only question is how do I export the SSL cert in the correct format for 3CX and how do I get it into the 3CX config?
    Cheers
    Gareth
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,343
    448
  3. gwinn
    Oct 4, 2007
    This is ok in theory except that an exported certificate from IIS comes in in a pfx file extension. Is there a way of importing a PFX file?
  4. YiannisH_3CX
    May 10, 2016
    6,343
    448
    You could just opt for a 3CX FQDN and certificate which auto renews as long as you have an active maintenance. You can also re-install the system and import the PFX certifcate or you can convert it. Google can help you with the last option
