Postgres Database Server Service Will Not Start
Discussion in '3CX Phone System - General' started by malcolmh, Feb 4, 2008.
  1. malcolmh
    Feb 4, 2008
    I'm new to 3CX and VoIP. My problem is that when I installed the system as a trial over our intranet everything worked fine but when I had to reboot the server running the system the Postgres Database Server Service did not start even though it is set to Automatic. When I tried to start it manually it I get ' Error: 1069-The service did not start due to logon failure'. When I go to the service logon tab it is asking for a username and password for thr '\phonesystem_3cx_' account. This is where I am stuck as I do not have them. Is there a default username and password and why do I get this problem?
    Thanks for reading :cry:
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,936
    250
    Did you remove the phone system user by any chance from windows?
  3. malcolmh
    Feb 4, 2008
    As far as I know not. I just rebooted the server.
  4. jantoney
    Nov 20, 2007
    60
    Hey,
    to rule out anything that you may have/have not done try reinstalling the 3cx system.
    dl the latest version (v3790) and install it with out uninstalling the old version. This should keep any settings you may have put in there but should reset everything else.
    http://www.3cx.com/ip-pbx/downloadlinks.html
    one more thing to try... in services tick on the box that allows the service to interact with the desktop, and try setting the service to start using the local system credentials...
    It may give you more of an error if it fails and it can interact with the desktop...
    all else fails... uninstall the whole thing and install again... it may be something that changed before you restarted and was only a once off thing.
    also...
    - what version did you install?
    - on what operating system?
    - What Antivirus are you running?
    - Can you get into the 3CX web based control pannel at all?
    - Are there any other relevent logs in Event Viewer around the same time that log is posted?
  5. malcolmh
    Feb 4, 2008
    Thanks for all that, a very comprehensive reply much appreciated. I'll work my way through your suggestions and let you know how I get on. 8)
  6. AndreasMetal
    Nov 16, 2007
    62
    AAh..Experiencing the same problem..
    But in my case the 3CX Database Server Service can't Begin. All other 3cx Services can begin, but Database Service not.
    After that, I downloaded again the 6th Version of 3CX but it says, that it can continue because 3CX Database server can't start..:(
    PlEaSe HeLp,
    any help/comment will be apreciated
  7. worksighted
    worksighted New Member
    Aug 19, 2008
    204
    If you go into the services control panel and right click "3CX Database Server" and select properties....go to "log on" tab....what user is the process running as?
    Mike
  8. AndreasMetal
    Nov 16, 2007
    62
    User: phonesystem__3cx__
  9. jim@itstod.se
    jim@itstod.se New Member
    Apr 7, 2008
    100
    We had the same problem two weeks ago after we made the server where 3CX is installed on a secondary domain controller.
    Adding the phonesystem__3cx__ user to the security policy "Log on as a service" under "Default domain controller security settings" and rebooting the server solved the problem for us.
