- Joined
- Jan 22, 2015
- Messages
- 61
- Reaction score
- 6
I'm trying to get some info from database with CFD component but I'm unable to even connect to it. Any suggestions? I checked the credentials and the query with pgadmin installed on the same server as 3cx and it's working.
Please help
Code:
PlugIn[my_plugin - DatabaseAccessComponent - CallID PLGEWSATALBQ] Trace: Start executing component with server='########.###' - port='3306' - database='######_0000003' - userName='#####_0000003' - password='!qo1ShvLEO!L' - statementType='Query'
17-09-08 14:57:26.149|100049| Trc|75|0038|: PlugIn[my_plugin - DatabaseAccessComponent - CallID PLGEWSATALBQ] Trace: Command to execute: SELECT *
FROM `CID`
WHERE `ext` = 200
AND `last` = FALSE
17-09-08 14:57:26.555|100030| Err|10|0038|: PlugIn[my_plugin - Callflow - MainFlow - CallID PLGEWSATALBQ] ERROR: Error executing last component: System.InvalidOperationException: Internal connection fatal error. Error state: 18
at System.Data.SqlClient.TdsParserStateObject.TryProcessHeader()
at System.Data.SqlClient.TdsParser.ConsumePreLoginHandshake(SqlAuthenticationMethod authType, Boolean encrypt, Boolean trustServerCert, Boolean integratedSecurity, Boolean& marsCapable, Boolean& fedAuthRequired)
at System.Data.SqlClient.TdsParser.Connect(ServerInfo serverInfo, SqlInternalConnectionTds connHandler, Boolean ignoreSniOpenTimeout, Int64 timerExpire, Boolean encrypt, Boolean trustServerCert, Boolean integratedSecurity, Boolean withFailover, Boolean isFirstTransparentAttempt, SqlAuthenticationMethod authType)
at System.Data.SqlClient.SqlInternalConnectionTds.AttemptOneLogin(ServerInfo serverInfo, String newPassword, SecureString newSecurePassword, Boolean ignoreSniOpenTimeout, TimeoutTimer timeout, Boolean withFailover, Boolean isFirstTransparentAttempt)
at System.Data.SqlClient.SqlInternalConnectionTds.LoginNoFailover(ServerInfo serverInfo, String newPassword, SecureString newSecurePassword, Boolean redirectedUserInstance, SqlConnectionString connectionOptions, SqlCredential credential, TimeoutTimer timeout)
at System.Data.SqlClient.SqlInternalConnectionTds.OpenLoginEnlist(TimeoutTimer timeout, SqlConnectionString connectionOptions, SqlCredential credential, String newPassword, SecureString newSecurePassword, Boolean redirectedUserInstance)
at System.Data.SqlClient.SqlInternalConnectionTds..ctor(DbConnectionPoolIdentity identity, SqlConnectionString connectionOptions, SqlCredential credential, Object providerInfo, String newPassword, SecureString newSecurePassword, Boolean redirectedUserInstance, SqlConnectionString userConnectionOptions, SessionData reconnectSessionData, DbConnectionPool pool, String accessToken, Boolean applyTransientFaultHandling)
at System.Data.SqlClient.SqlConnectionFactory.CreateConnection(DbConnectionOptions options, DbConnectionPoolKey poolKey, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningConnection, DbConnectionOptions userOptions)
at System.Data.ProviderBase.DbConnectionFactory.CreatePooledConnection(DbConnectionPool pool, DbConnection owningObject, DbConnectionOptions options, DbConnectionPoolKey poolKey, DbConnectionOptions userOptions)
at System.Data.ProviderBase.DbConnectionPool.CreateObject(DbConnection owningObject, DbConnectionOptions userOptions, DbConnectionInternal oldConnection)
at System.Data.ProviderBase.DbConnectionPool.UserCreateRequest(DbConnection owningObject, DbConnectionOptions userOptions, DbConnectionInternal oldConnection)
at System.Data.ProviderBase.DbConnectionPool.TryGetConnection(DbConnection owningObject, UInt32 waitForMultipleObjectsTimeout, Boolean allowCreate, Boolean onlyOneCheckConnection, DbConnectionOptions userOptions, DbConnectionInternal& connection)
at System.Data.ProviderBase.DbConnectionPool.TryGetConnection(DbConnection owningObject, TaskCompletionSource`1 retry, DbConnectionOptions userOptions, DbConnectionInternal& connection)
at System.Data.ProviderBase.DbConnectionFactory.TryGetConnection(DbConnection owningConnection, TaskCompletionSource`1 retry, DbConnectionOptions userOptions, DbConnectionInternal oldConnection, DbConnectionInternal& connection)
at System.Data.ProviderBase.DbConnectionInternal.TryOpenConnectionInternal(DbConnection outerConnection, DbConnectionFactory connectionFactory, TaskCompletionSource`1 retry, DbConnectionOptions userOptions)
at System.Data.SqlClient.SqlConnection.TryOpenInner(TaskCompletionSource`1 retry)
at System.Data.SqlClient.SqlConnection.TryOpen(TaskCompletionSource`1 retry)
at System.Data.SqlClient.SqlConnection.Open()
at my_plugin.DatabaseAccessComponent.prepareCommand(IDbConnection conn, QMExtendAPI iface, String id)
at my_plugin.DatabaseAccessComponent.executeReader(IDbConnection conn, QMExtendAPI iface, String id)
at my_plugin.DatabaseAccessComponent.executeStatement(IDbConnection conn, QMExtendAPI iface, String id)
at my_plugin.DatabaseAccessComponent.executeStart(QMExtendAPI iface, String id)
at my_plugin.DatabaseAccessComponent.Start(QMExtendAPI iface, CallQueue callQueue, QueueCall queueCall, ActiveConnection activeConnection, TimerManager timerManager, Dictionary`2 variableMap, TempWavFileManager tempWavFileManager, PromptQueue promptQueue)
at my_plugin.Callflow.ProcessStart()
Please help
