POTS lines
Discussion in '3CX Phone System - General' started by purebulk, Jul 7, 2015.
  1. purebulk
    May 6, 2015
    I have one POTS line I am using a CISCO SPA-3102 ADA to interface with 3CX pbx. I have a ring group assigned to answer the line and everything works fine unless no one in the ring group answers the line. If that happens it should forward to another backup ring group. When the transfer tries to take place the caller receives a fast busy signal.
    I have setup my VOIP lines to forward in this manner and the caller never receives a busy signal.
    Any idea what would cause this to go to a busy signal going toward the secondary ring group?
  2. Charles_3CX
    Charles_3CX New Member
    3CX Support
    Jul 6, 2015
    114
    Hi this sounds very interesting, can you open a support call so we can investigate it for you? Thanks
  3. leejor
    11,126
    330
    Post , or look over, the 3CX Server log, of one of these failed calls. There may be an explanation of what is happening to the call.
