Power Went Out And Now Server Won't Work
Discussion in '3CX Phone System - General' started by refiking, Aug 21, 2008.
  1. refiking
    Jul 2, 2008
    12
    The power went out for about 20 - 30 seconds earlier and now when I restarted the computer, the 3cx server won't register the line. Thus, I'm offline. Here's the server log. Please help!
    14:31:48.039 CallCtrl::thread [CM501008]: *** Stopped Calls Controller thread ***
    14:31:45.025 CServiceModule::preMessageLoop [CM100001]: *!* Failed to initialize Call Manager *!*
    14:31:45.025 CallMgr::Initialize [CM100001]: *!* Failed to initialize SIP Stack *!*
    14:31:39.978 CallMgr::findLocalIPs [CM101001]: Can not determine any local IP Address!
    14:31:39.808 MediaServerConnected [CM112000] Media Server is connected
    14:31:39.287 CallCtrl::thread [CM501007]: *** Started Calls Controller thread ***
    14:31:39.287 CallMgr::Initialize [CM501002]: Version: 6.0.650.0
    14:31:39.287 CallMgr::Initialize [CM501001]: Start 3CX PhoneSystem Call Manager
    14:31:38.886 LoadLicenceInfo [CM501010]: License Info: Load Failed
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    please try to make another rebbot of the machine where 3cx is installed. If possible make it a cold reboot (shutdown and restart after 10 seconds)
    After restarting see if the lines get registered.
    regards
  3. SIPfun
    Jun 23, 2008
    56
    Check your network gear too... Sometimes power blips hang them up. A power reset of those may help as well.
  4. galal202
    galal202 New Member
    Jun 23, 2008
    235
    I think it's better to reinstall 3cx specialy if you have a backup
  5. refiking
    Jul 2, 2008
    12
    You guys are right. I just reinstalled a fresh copy and backed up the old copy so everything is back up and running. Thanks!
