Pre-answer message
Discussion in 'Ideas' started by edipoles, Nov 20, 2015.
  1. edipoles
    Sep 24, 2014
    Is it possible to provide a pre-answer message (or sound) on an extension which would be played while ringing here?
    All standard phone systems offer it.
    Thank you in advance.
    Regards,
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    I do not understand where this plays?
    In the office on the ringing handset or on the caller end?
