Pre Configure Best Practice
Discussion in '3CX Phone System - General' started by full2, Apr 28, 2017.
  1. full2
    Nov 18, 2015
    20
    So what does everyone do for pre-configuration then move to site? I keep hitting these little annoyances. Example: I pre-configure a server in our office, everything is working and I set the the provision link to local interface 192.168.66.x and everything is great. Take it to office where there subnet is different and find out that I need to reinstall 3CX because it will not change the provisioning link based on the interface IP even though I set it to local. Seems like a pain.
  2. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    944
    154
    Well the step you are missing is to do a backup and restore. Then all of your settings will persist but you can change the IP scheme (properly) on restore.
  3. neville
    neville New Member
    Apr 23, 2012
    208
    34
    We normally simulate the clients network using a DMZ network on or firewall. This way, we only need to change the WAN at the client site. We set the wan ip to dynamic and get our outside dmz address. Once on the clients network, change wan IP to static, enter their wan IP, and you are up and going.
