predictive dialer + sql server 2014
Discussion in 'Call Flow Designer' started by zouve, Mar 9, 2018.
  1. zouve
    Mar 9, 2018
    10
    hi,
    i have a problem i can't make the predictive dialer work
    i have created a table in my db with two columns id, phones varchar(50) and in CFD i have modified the predictive dialer project
    please look the screenshot attached
    i have used the predictive dialer last month but with txt file
    any suggestions??? .
    thanks in advance
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,598
    125
  3. zouve
    Mar 9, 2018
    10
    i found what it was
    but know i have another problem i think that the PredictiveDialerDemo.tcxvoiceapp running again after the Dialer cycle finished is it normal ?
  4. edossantos
    Jun 27, 2007
    1,598
    125
    Yes, the dialer will keep looping, always looking for new calls to make...
  5. zouve
    Mar 9, 2018
    10
    is there anyway to stop after the first pass?
    i have a table with 500 telephones when it reach the 500 phone to stop
  6. edossantos
    Jun 27, 2007
    1,598
    125
    Hi @zouve,
    Yes, of course, you just need to add a Condition component and check if it's time to make calls or not... If it is, you continue executing the components you have now to make the calls, otherwise you do nothing...
    Kind regards.
  7. zouve
    Mar 9, 2018
    10
    how can i add delay between calls or something like that?
  8. edossantos
    Jun 27, 2007
    1,598
    125
    You need to write the state to some persistent place. You can use a text file, a database, etc. When you don't want to make more calls, you can write that to a file for example, and then you check the file every time the dialer cycle starts...
  9. zouve
    Mar 9, 2018
    10
    maybe I described it wrong. I want to limit the call rate to max 3 per second because this is what our provider has asked for. how can I define this?
  10. edossantos
    Jun 27, 2007
    1,598
    125
    To do that maybe it's better configuring the dialer as a "power dialer" instead of "predictive dialer". This way, you can configure the number of parallel dialers, and the pause between cycles. So for example, you can configure 30 dialers, and a pause of 10 seconds between cycles. This way the dialer flow will be executed 3 times per second in average. You just need to make 1 call for every dialer cycle.
  11. zouve
    Mar 9, 2018
    10
    i made an external script and i put inside a thread.sleep !!!!
    it works
    #11 zouve, Mar 15, 2018
  12. zouve
    Mar 9, 2018
    10
    can in my db save what happens with the call each time in a separate column?
    if he or she answered the outbound call or not etc .....
  13. edossantos
    Jun 27, 2007
    1,598
    125
    When you use the MakeCall component, the call is made asynchronously and you don't have any feedback about the call result. So you need to perform some postprocessing in order to get that information. You can take the information from CDRs, or you can connect the calls to a CFD app, which writes the "successful" information to your database, and then transfers the call to the destination that needs to handle the call...
