Prefered Codecs for Grandstream GXW4104
Discussion in '3CX Phone System - General' started by anjodatec, Aug 14, 2015.
  1. anjodatec
    Aug 14, 2015
    inside this gateway there is an option to set the prefered codec order - the default is outlined below.
    >>> Should we change?
    Tks
    Renato P
    Preferred Vocoder(in listed order):
    choice 1: PCMU
    choice 2: PCMA
    choice 3: G723.1
    choice 4: G.729A/B
    choice 5: GSM
    choice 6: GSM
    choice 7:pCMU
    choice 8: PCMU
    10,586
    252
    Re: Prefered Codecs for "Unsupported IP Phone" GXW4104
    The first two are the G711 (U & A) codecs and will give the best voice quality, they also consume the most "bandwidth". The only reason to use others is compatibility, or, to conserve bandwidth, if that is an issue. Within a LAN, that is usually not an issue, and you do want the best quality sound, so I would leave it as is, or at least leave the first two in place.
    I have run into issues passing DTMF tones (audible), when not using G711 codecs.
