Preferences not saved for VoIP Client
Discussion in 'Windows' started by Vali_3CX, Jul 15, 2009.
  1. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,482
    67
    Hi, Simple
    Voip Client is no longer supported by us. However, try following thing first and tell me the result:
    - start the voip client
    - select the device you want (including saving).
    - exit the phone (I mean exit (File/Exit), not minimize to tray)
    - start it again and check if the device you previously set are used.
    In the VoipPhone we had such kind of issue with "plug-and-play" audio devices, such as ones from headsets, which can be dynamically added/removed, so we implemented a mechanism to accomodate these changes with user's preference, mechanism not implemented in the Voip Client you use.
    Therefore, I assume your Voip Client is starting BEFORE application installing these devices - it checks for them, doesn't found them, therefore it switch to Windows default ones.
    Tell me if this assumption is correct and, if is, then we will try to find a fix.
    Regards
    vali
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    hello,
    first try to install the lastest version of 3cx. next verify if aspnet user have administrator privilège. and test with an other explorer if it's work, ex firefox.
    have good day
  3. Vali_3CX
    Dec 12, 2008
    1,482
    67
    Huh? :roll: :lol:
  4. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    :cry: you don't understand me ? or you are not ok ? :cry:
  5. Vali_3CX
    Dec 12, 2008
    1,482
    67
    Simple refers the 3CX VoIP Client - Voip Client has absolutely nothing to do with ASP.NET, administrator privilege, explorer and firefox 8)
    Cheers
    vali
  6. Vali_3CX
    Dec 12, 2008
    1,482
    67
    Hi, Simple
    Our official softphone is 3CX Voip Phone since several months - you may download from here (~2.2MB)
    http://www.3cx.com/downloads/3CXVoIPPhone3.msi
    Try it and see if it works ok in the same conditions - looking forward for your feedback
    vali
  7. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    houuu :shock:
    yes i have not understand everyone houu i'm very tired.i understand that in 3cx admin interface :arrow:
    sorry
  8. Vali_3CX
    Dec 12, 2008
    1,482
    67
    Hi, Simple
    Thanks for your feedback. The answering (popup) behavior, including stealing focus, has been already changed as you want since quite time ago, so it will be available - among other features and fixes - on the next release.
    Regards
    vali
