Preffered outsideLine
Discussion in '3CX Phone System - General' started by mrLunkwill, Feb 13, 2007.
  1. mrLunkwill
    Oct 15, 2006
    7
    Hi I have 10 VoIP lines from the same operator - and its no problem to say that
    Line 0 - Call on Every Externsion
    Line 1 - Call Externsion 101
    Line 2 - Call Externsion 102
    and so on - but What I want is then Externsion 101 press 0 (for an outside line) I want to give him Line 1 (For correct callerId)
    I want all externsion to press 0 (i.e. I dont want a solution where you have to press 01 form line 1 02 for line 2 etc etc )
    Can i do this somehow?
    (And because its the same operatior I cant add multiple VoIP Provider - or? If I can to that its maybe the best solution.)
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    At the moment that is not supported by the system.
  3. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    Hi, what you would have done is created an outbound rule for each extention.
    All rules would be for calls with prefix '0'. Each one would apply for a different extension and for each extention the rule would place the call on a different line.
    Currently you cannot specify a line, and Outbound rules can only place calls to specific VoIP Providers or gateways.
