Prefix for Address Books for iOS Client
Discussion in 'iOS' started by matt11, Jul 27, 2017.
  1. matt11
    Jul 30, 2013
    I believe this used to be a configuration setting in previous versions, but there seems to be no way to setup a prefix for outbound calls in iOS. I have also noticed this was removed in the CRM integration as well (we have clients that use outlook to dial out, but they don't want to have to add a 8 or 9 in every single phone entry). Is there an easy way to do this or do we have to completely redo the outbound rules to try to accommodate external calls instead of dialing a prefix?
