Prefix in caller-id
Discussion in '3CX Phone System - General' started by MatsW, Jan 8, 2010.
  1. MatsW
    Mar 10, 2009
    50
    I have a SNOM-370 attached to my 3CX, where the 3CX outbound rule is configured to detect "0" as outbound prefix, and to strip it off before doing the outgoing call.
    But the Snom370 log for external incoming calls doesn't contain a leading zero why I can't directly call back using the log in the SNOM.
    So, is there some way to configure 3CX to get a "0" prepended to caller-id on incoming calls?
  2. comresource
    comresource Member
    May 22, 2009
    303
    You could create another outbound rule matching the length of the outbound call with no "0"
  3. MatsW
    Mar 10, 2009
    50
    Would that add a prefix-"0" to the caller-id on incoming calls?
  4. galal202
    galal202 New Member
    Jun 23, 2008
    235
    this will not add 0
    Please read this and topic in it to support
    http://www.3cx.com/forums/remove-area-code-settings-for-each-line-11388.html#p67835
