prefix to dial from missed calls
Discussion in '3CX Phone System - General' started by coreun, Sep 17, 2013.
  1. coreun
    Dec 22, 2011
    6
    Hi:
    I need to know if there is any solution to add a prefix to missed calls. In our customer dialplan you need 0 to dial a external call but it is no added when have a missed call for that you can´t redial from missed call. Is there any mode to add prefix in incoming calls?
    Regards,
    Diego.
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    I assume you have a patton gateway and on incoming calls its leaving off the zero of the phone number so when you try to call back it says number not found?
    if this is the case, a simple fix can be applied to the gateway to insert the missing zero so you can then redial the missed calls.
  3. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Are you in Italy ?
    Than can you prepend +39 on GW Patton , you can manage Patton where ISDN Number Plan type = unknow ( in italy mobile device ) prepend +39 , manage ISDN Numebr Plan Type = nationl ( in italy call from National ) prepend +390 .
    On 3Cx you can create dial rule where +39 go to trunk
    By
    Bruno
  4. stobby256
    Sep 9, 2013
    27
    Same issue here in the UK...
    We dial '9', but it's not prepended when dialling it back...
    Grandstream Gateway, 4104.
    Just point me in the right direction!
    Steve
  5. StefanW
    Jun 2, 2009
    1,181
    76
    V12 next update will slove all of these questions
  6. stobby256
    Sep 9, 2013
    27
    Any idea when, Stefan?
  7. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    how you solved it?
