Prepend/append ring group name to blocked/anonymous calls
Discussion in '3CX Phone System - General' started by rmayer, Apr 18, 2010.
  1. rmayer
    Jan 7, 2010
    58
    Is there a way to prepend/append group names to blocked/anonymous calls? This feature only works if the caller has a caller ID and our staff need to be able to tell which ring group the caller dialed, even if the caller has a blocked/anonymous number.
  2. nb
    nb Support Team
    Jun 7, 2007
    2,117
    145
    Can you send us the logs for this?
  3. rmayer
    Jan 7, 2010
    58
    How far do the logs usually go back? I did the tests on Saturday and the logs only seem to go back 1 day.
  4. nb
    nb Support Team
    Jun 7, 2007
    2,117
    145
    no make the test now and generate the logs right then.
    Problem is that to avoid CPU usage we switch off backup of logs.
    Set the logging to verbose and you will keep the logs of the previous days - But I d rather you send us conpact logs.
    best thing to do is, set to verbose, restart the services, replicate the problem and send me the logs immediately telling me that call number 5 for example failed.
  5. rmayer
    Jan 7, 2010
    58
    No problem, I'll try to do another test this week.
  6. rmayer
    Jan 7, 2010
    58
    Attached,
    Any call that is anonymous or blocked will not show the group name...
  7. rmayer
    Jan 7, 2010
    58
    Turns out this is an issue with Cisco phones, the softphone and polycoms display correctly. I read in another forum that the solution was to change AnonymousCaller to Unknown... is there a way to do this in 3CX?
  8. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    Re: Prepend/append ring group name to blocked/anonymous call
    The same bug here. no solution where found ?
  9. TomBarker
    Feb 25, 2013
    12
    Anyone found a solution to this. We use Cisco SPA504G and all anonymous calls simply show as "anonymous" no ring group or call queue information.
