Prepend on internal calls
Discussion in 'Ideas' started by Bradley Haylock, Apr 5, 2017.
Would prepend on internal calls be useful?
  1. Yes
    50.0%
  2. No
    50.0%
  1. Bradley Haylock
    Feb 25, 2017
    We would find the following feature really useful. Our client currently has five digit extension number, made up as follows, first two digits are property code and then the last three digits are the local extension numbers. If we could prepend on numbers of a certain length (in this case 3 digits), we would be able to set this up, so local users would only need to dial their "local" 3 digit extension numbers.
    11,073
    323
    This can be done on sets that have an internal dialplan.
