Presence based on mouse movement
Discussion in 'Windows' started by gavpop, Mar 24, 2017.
  1. gavpop
    Jul 24, 2012
    29
    Is there a way for the 3cx client to automatically alter presence information based upon computer activity?
    ie - if mouse has moved in past 2 minutes, set presence as available.
  2. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
  3. gavpop
    Jul 24, 2012
    29
    Thanks - that's just what I'm looking for.
    Next question - How can I set this setting centrally? ie, to update all clients across the network?
