Presence for 3CX soft client using FQDN
Discussion in '3CX Phone System - General' started by DARSFoG, Feb 23, 2017.
  1. DARSFoG
    Dec 20, 2016
    19
    Long story short I have a very complicated network hosted firewall that is keeping presence from working.
    3CX system
    Internal IP: 192.168.1.7
    External IP : xxx.xxx.xx1.228
    Test System:
    Internal IP: 192.168.1.224
    External IPL xxx.xxx.xx1.224
    Anything outside of the network can get presence. It's only machines/clients internally that can't. I can make calls from the soft-client just fine. Wireshark confirms that presences is trying to use the FQDN instead of the local IP of the 3CX system.
    Is there anyway to change this behavior? I've never had this issue, but at the same time I've never had to deal with a very complicated hosted firewall.
    Thoughts?
  2. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
    And in that complicated network there is no local DNS which should resolve it to 192.168.1.7?:confused:
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,978
    183
    Basically setup the FQDN on the internal DNS?
    If you do not have an internal DNS server - then you need to reconfigure 3cx.
  4. DARSFoG
    Dec 20, 2016
    19
    There is an internal DNS and does have the FQDN resolving to the internal IP.
    Here is the kicker that I should have included.
    Nmap scan of local IP shows all required ports open.
    Nmap scan of FQDN does not show required ports open.
    Nmap scan of FQDN from outside network shows required ports open.
  5. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
  6. craigreilly
    Feb 1, 2012
    2,978
    183
    My guess is that NMAP is not using internal DNS server to resolve name of FQDN to internal IP. I haven't used it... but ut seems that is the case based on the 3 behaviors you state.
  7. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
    From this example we can see how important is to have a mobile workstation/server powered by ESXi as drop-in replacement for DNS or even SG-1000?:cool:
  8. craigreilly
    Feb 1, 2012
    2,978
    183
    Why do we need an ESXi powered machine?
  9. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
    Only for convenience? It should be quickest way to confirm by simply starting pfSense appliance?
    It's unlikely that 3CX softphone will change it?:confused:
  10. DARSFoG
    Dec 20, 2016
    19
    Just an update. I ended up backing up the config and reinstalling 3CX and it seemed to solve the issue. So... I have no idea.
