Presence in Bria and X-Lite
Discussion in '3CX Phone System - General' started by infostudi, Apr 8, 2008.
  1. infostudi
    Dec 11, 2007
    I've noticed with pleasure that the latest build (5.1.4393) is able to manage presence with Counterpath products (X-Lite, eyeBeam and Bria).
    However, it isn't working properly, because I see all extensions online (green light), even if they are unregistered.
    Are there any special settings to make in order to have a correct behavior?
    Thanks!
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    304
    So far presence/BLF is only tested with Grandstream, SNOM and Aastra. However we will consider making it compatible with the Xlite products in future versions.
    That said, do you have a commercial version? Note that the free edition does not include BLF/Presence features
  3. infostudi
    Dec 11, 2007
    Thank you for the quick answer.
    Currently I'm using the free version.
    Are you going to support also X-Lite instant messaging?
  4. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    We're going to support instant messaging. If XLite does it in a standard way - it will be supported.
