Solved Presence info for mobile calls
Discussion in 'iOS' started by michaelsalzburg, Dec 8, 2016.
  1. michaelsalzburg
    Sep 4, 2012
    i have a question about the presence information when using the iOS app (current version from 24.11.2016):
    Is it possible that the 3CX client recognizes when a call via the standard mobile network (non-3CX) is currently active to automatically set the presence information?
    Reason for that is, that it would be great if colleagues could see that I'm in a call with my cellular network at the moment as they could if I would do the call with the 3CX system.
    I hope I could describe this understandable. Thanks for any help!
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,438
    61
    We had it implemented, experimentally, about two years ago, for about 6 months, but we droped it because proved to be highly unreliable, and we don't have any plans to re-implement it. A simple case to be answered: how do you launch 3CX client app when a GSM call is incoming via the standard mobile network?
  3. michaelsalzburg
    Sep 4, 2012
    Thanks for your answer. I can follow your argumentation and understand your point. ;-)
