Solved presence not showing right in mac os client
Discussion in 'iOS' started by georgi0, Mar 20, 2017.
Tags:
  1. georgi0
    Feb 14, 2017
    28
    can you help me fix this problem?
    thanks
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,479
    67
    Hi Georgio
    Georgio, while in the Presence, please try to resize right the 3CX client (unlike Windows, MACOS doesn't show a window's resizing frame, and the 3CX MAC client is resizable). Also you may try, while in the Presence, in the 3CXClient menu, to click Re-register. Please tell me if any of these two tests fix the display problem.
    vali
  3. georgi0
    Feb 14, 2017
    28
    yes i did, but nothing changed.
    thanks anyway.
  4. Vali_3CX
    Dec 12, 2008
    1,479
    67
    If you want, today or next week, please send me by PM one eMail address where I could send you next week some 3CX client debug .DMGs.
  5. Vali_3CX
    Dec 12, 2008
    1,479
    67
    OK, thanks Georgio for helping us:
    It seems the problem is the Arial font being disabled or missing in the system.
    Exit the 3CX client then open Finder/Applications/Font Book.app. In All Fonts scroll to Arial. If not present, you have to reinstall it (it's a system font) Otherwise, it should have been disabled and it should looks like in attached screenshot. Righ-click it and choose Enable "Arial" Family, then start the 3CX client again.
    #5 Vali_3CX, Mar 29, 2017
  6. georgi0
    Feb 14, 2017
    28
    it was my pleasure to assist you in helping me solve this issue.
