Presence on Android 4.4.4
Discussion in 'Android' started by hcarmine, Dec 5, 2014.
  1. hcarmine
    Jun 5, 2010
    Hello, good evening.
    My Syste
    I have a 3cx V12 Server is licensed for 16 concurrent calls
    We have some problems with new android phones and Iphone
    Our customers have reported failures and I did some testing.
    Samsung Galaxy S5 with Android 4.4.2
    works fine
    Sony Z3 with Android 4.4.4
    Connects but does not show the phonebook or the presence
    IPhone 5
    I await help
    Thank you
    11,073
    323
    Are these phone being used on the local LAN, or remotely?
  3. hcarmine
    Jun 5, 2010
    Hello
    My server has an real fixed ip address and my phones work on 4G or wifi remotly.
  4. leejor
    11,073
    323
    And this is happening on both 3/4G and wifi?
    Does it work, on the same phones, internally (local LAN)?
    If so, I'm assuming that the correct port for presence is forwarded, 5000 or 5001.
    http://www.3cx.com/blog/docs/ports-used/
  5. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,530
    298
    I am on an iPhone 6+ from T-Mobile and can get presence/contacts both on 4G and WiFi outside of the office.
    Single NIC Card, Outbound NAT - private address to public IP, Inbound Port Forwarding - Public IP to private address.
    I didn't have much luck with presence/contacts when we tried SSL (HTTPS) - and are now just HTTP since I changed server hardware recently.
  6. hcarmine
    Jun 5, 2010
    Samsung Galaxy S5 works fine, but the android version is 4.2.2
    On Sony Z3 and Z3 compact dont work, the android version is 4.4.4
    On IPhone 5 32Gb dont work.
    Wait, thanks.
    Henrique Carmine
  7. leejor
    11,073
    323
    Can't speak (from experience about the iPhone as i don't use it), but with the Sony's, it may be the Android version, although 4.4.4 has been out awhile...or it may be the phones themselves (coincidence that it is happening on two Sony phones?). That could break down to an option (default?) that is preventing Presence from working, an add-on placed on the phone by a Provider, or an App that is running.
    You could try stopping any Apps that have been added to the phone since it's acquisition as most that come with the phone will restart automatically, but it doesn't hurt to try.
    Perhaps someone , using the same phone/same android release, can comment.
