Presence shows 'Not Connected' when outside the LAN
Discussion in 'iOS' started by MB1, May 23, 2015.
  1. MB1
    MB1
    Nov 2, 2007
    39
    Hi All,
    I cannot get the presence 'Available' to work whilst outside the LAN. I am able to login and make calls without any issues. I have tried with Windows firewall on and off, but it does not make any difference.
    3Cx v12.5 on Windows Server 208 R2 SP1. FQDN internal and external resolving correctly. All required ports including 5000 and 5001 TCP are open.
    Thanks in advance.
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    Did you provisioning the phone with the welcome email?
  3. afinite
    Mar 11, 2012
    18
    I have the same issue, but can't see what's going wrong. The provisioning email was used. The settings look fine and calls work in terms or dialling and audio.
  4. sunics
    Jan 9, 2014
    i've also the same issue.. i do the provisoring with the welcome email.
    i can do calls but i can't change the presence cause there is "not connected"
    has anyone an idea what this means?
    i use 3cxPhone for Iphone v. 12.1.10 with the 3cx 12 SP6
  5. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Take another approach to verify your port is open/forwarding.. open the management site from your browser, outside of the office, and using whatever the app is pointing to.
    If that isn't working, you still have a "network" problem, not a "3CX" problem.
  6. DesCheah
    Dec 22, 2014
    10
    Hi guys,
    I do have the same issue with Presence Info shows on both Android and iOS devices. Try to open port 5000 and 5001 on the firewall and this worked for me. Thanks
