presence status on yealink T46s
Discussion in '3CX Phone System - General' started by @lä, Mar 8, 2018.
  1. @lä
    Mar 1, 2018
    5
    Is it possible to show the presence status of team mates on a yealink T46s? I want to see who is avaiable, on hook, away, etc. As of right now, the BLFs are always just green (the actual LED as well as the icon next to it).
    Any ideas?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,368
    535
    Please note that presence works only in the 3CX client or Web client. You cannot have presence on IP phones. BLF buttons can only display if a person is busy or not. Since you are using Yealink phones you can use the Web client or the 3CX client in CTI mode and get the presence info from the client.
    @lä likes this.
  3. @lä
    Mar 1, 2018
    5
    Thank you for clarification
