way
Platinum Partner
- Joined
- Feb 21, 2011
- Messages
- 48
- Reaction score
- 4
Hello
I have 2 VoIP providers which both have their own unique DID for each extension. I'm wanting an extension to present caller ID 1 to VoIP provider 1 and caller ID 2 to provider 2 but can't see a way of doing this. I can set a single outbound caller ID in the extension settings, but there doesn't seem to be a way to add a second one. None of the extensions will have the same DID for either VoIP provider.
Is there a way of presenting separate outbound DID's for each extension on both trunks? Caller ID reformatting seems like it might work, but also seems like for a lot of extensions would be very tedious and fiddly to troubleshoot if an extension or DID changes.
Thanks for the help
Chris
Thanks for the help
Chris
