I don't think my last post went through, so here it is again. phone system restarted.
VoIP Provider supports. VoIP provider is also in the approved provider list.
inband
RFC2833
sip INFO
I hope this is what you needed. Here is the log you asked for.
18:29:29.864|.\Service.cpp(213)|Log2||??:*** Initialize ***
18:29:29.864|.\Service.cpp(236)|Log2||??:Local port range is set to:7000-7499
18:29:29.864|.\Service.cpp(251)|Log2||??:External port range is set to:9000-9015
18:29:29.879|.\Service.cpp(297)|Log2||??:*** Start Server ***
18:29:29.879|.\Service.cpp(44)|Log2||??:*** Listen ***
18:29:29.879|.\FileCache.cpp(275)|Trace5||??:Cache size changed: file=5242880(0) total=62914560(3057052532)
18:29:29.879|.\Service.cpp(63)|Log2||??:*** Connecting to [127.0.0.1:5482] ***
18:29:29.879|.\FileCache.cpp(235)|Trace5||??:Cache (*.wav) in directory ..\data\http\prompts
18:29:29.895|.\Service.cpp(68)|Log2||??:*** Connected to deathstar:5482/CallManager at 127.0.0.1:5482 ***
18:29:29.926|.\Service.cpp(90)|Log2||??:*** Connecting to [127.0.0.1:5483] ***
18:29:30.848|.\Service.cpp(101)|Log2||??:IVR not found on 127.0.0.1:5483
18:29:31.535|.\FileCache.cpp(235)|Trace5||??:Cache (*.mp3) in directory ..\data\http\prompts
18:29:31.535|.\FileCache.cpp(235)|Trace5||??:Cache (*.wav) in directory ..\data\ivr\prompts
18:29:31.879|.\Service.cpp(90)|Log2||??:*** Connecting to [127.0.0.1:5483] ***
18:29:32.972|.\Service.cpp(101)|Log2||??:IVR not found on 127.0.0.1:5483
18:29:33.987|.\Service.cpp(90)|Log2||??:*** Connecting to [127.0.0.1:5483] ***
18:29:34.971|.\Service.cpp(101)|Log2||??:IVR not found on 127.0.0.1:5483
18:29:35.971|.\Service.cpp(90)|Log2||??:*** Connecting to [127.0.0.1:5483] ***
18:29:36.440|.\Service.cpp(95)|Log2||??:*** Connected to deathstar:5483/IVRServer at 127.0.0.1:5483 ***
18:29:39.345|.\FileCache.cpp(235)|Trace5||??:Cache (*.mp3) in directory ..\data\ivr\prompts
18:32:34.625|.\MSEndPoint.cpp(682)|Trace5||??:Source ports: 9000 STUN RTP:75.77.11.170:9000 RTCP:75.77.11.170:9001 mapped to 75.77.11.170, ports 9000,9001
18:32:34.671|.\MediaServer.cpp(494)|Trace5||??:EndPoint created: (destination=sip.varphonex.com)
EndPoint: ID=00000001@(EXTERNAL)
LOGID=C:1.1 Status: MSEP_STUN
STUN RTCP:75.77.11.170:9001
Coder:
NOT SET
101:telephony-event
Party ptime:20
Party RTP:0.0.0.0:0
Party RTCP:0.0.0.0:0
Decoders:
<empty>
18:32:34.734|.\MediaServer.cpp(940)|Trace5||??:EP 00000001@ joined to call 1
18:32:34.734|.\MediaServer.cpp(949)|Trace5||??:starting send on new call 1
18:32:35.234|.\MediaServer.cpp(591)|Trace5||??:Set Party EP:C:1.1SDP:v=0
o=root 22664 22664 IN IP4 216.143.130.102
s=session
c=IN IP4 216.143.130.102
t=0 0
m=audio 28012 RTP/AVP 0 8 18 3
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:3 GSM/8000
a=silenceSupp
ff - - - -
18:32:35.234|.\MSEndPoint.cpp(2244)|Trace5||??:New state00000001@ SILENCE
18:32:35.234|.\MSEndPoint.cpp(1311)|Log2||??:[MS210000] C:1.1:Offer received. RTP connection: 216.143.130.102:28012(28013)
18:32:35.296|.\MediaServer.cpp(384)|Trace5||??:Virtual EndPoint created:
EndPoint: 00000002@(VIRTUAL)
EndPoint: 00000003@(VIRTUAL)
18:32:35.296|.\MediaServer.cpp(691)|Trace5||??:EP 00000003@. RTP stream is resumed
18:32:35.296|.\MediaServer.cpp(940)|Trace5||??:EP 00000003@ joined to call 1
18:32:35.577|.\MSEndPoint.cpp(2244)|Trace5||??:New state00000001@ ACTIVE
18:32:35.577|.\MSEndPoint.cpp(963)|Log2||??:[MS210003] C:1.1:Answer provided. Connection(transcoding mode):75.77.11.170:9000(9001)
18:32:35.577|.\MediaServer.cpp(529)|Trace5||??:Get Local SDP. EP:C:1.1SDP:v=0
o=3cxPS 92576677888 259795189761 IN IP4 75.77.11.170
s=3cxPS Audio call
c=IN IP4 75.77.11.170
t=0 0
m=audio 9000 RTP/AVP 0 8 18 3 101
a=fmtp:18 annexb=no
a=rtpmap:3 GSM/8000
a=rtpmap:101 telephone-event/8000
a=sendrecv
18:32:35.749|.\MSEndPoint.cpp(1498)|Trace5||??:EP:00000001@ refreshed
18:32:37.311|.\MediaServer.cpp(814)|Trace5||??:EP
[email protected] to play prompt
18:32:43.840|.\DtmfRecognizer.cpp(253)|Trace5||??
tmf sound detected key #6('6') pressed timestamp=62492
18:32:43.840|.\DtmfRecognizer.cpp(266)|Trace5||??:New tone #6('6') begin on 00000001@
18:32:44.746|.\DtmfRecognizer.cpp(253)|Trace5||??
tmf sound detected key #0('0') pressed timestamp=69700
18:32:44.746|.\DtmfRecognizer.cpp(266)|Trace5||??:New tone #0('0') begin on 00000001@
18:32:53.071|.\DtmfRecognizer.cpp(253)|Trace5||??
tmf sound detected key #0('0') pressed timestamp=138672
18:32:53.071|.\DtmfRecognizer.cpp(266)|Trace5||??:New tone #0('0') begin on 00000001@
tmf sound detected key #0('0') pressed timestamp=138764
18:32:55.539|.\DtmfRecognizer.cpp(253)|Trace5||??
tmf sound detected key #1('1') pressed timestamp=158496
18:32:55.539|.\DtmfRecognizer.cpp(266)|Trace5||??:New tone #1('1') begin on 00000001@
18:32:55.883|.\DtmfRecognizer.cpp(253)|Trace5||??
tmf sound detected key #1('1') pressed timestamp=158588
18:32:57.226|.\DtmfRecognizer.cpp(253)|Trace5||??
tmf sound detected key #1('1') pressed timestamp=171912
18:32:57.226|.\DtmfRecognizer.cpp(266)|Trace5||??:New tone #1('1') begin on 00000001@
tmf sound detected key #1('1') pressed timestamp=172004
18:32:58.414|.\DtmfRecognizer.cpp(253)|Trace5||??
tmf sound detected key #2('2') pressed timestamp=181388
18:32:58.414|.\DtmfRecognizer.cpp(266)|Trace5||??:New tone #2('2') begin on 00000001@
tmf sound detected key #2('2') pressed timestamp=181480
18:32:59.539|.\DtmfRecognizer.cpp(253)|Trace5||??
tmf sound detected key #2('2') pressed timestamp=190448
18:32:59.539|.\DtmfRecognizer.cpp(266)|Trace5||??:New tone #2('2') begin on 00000001@
tmf sound detected key #2('2') pressed timestamp=190540
18:33:20.036|.\MediaServer.cpp(814)|Trace5||??:EP
18:33:22.363|.\MediaServer.cpp(992)|Trace5||??:EndPoint 00000003@ removed from call 1
18:33:22.363|.\MediaServer.cpp(744)|Trace5||??:references to EndPoint 00000003@ were removed
18:33:22.473|.\MediaServer.cpp(985)|Trace5||??:EndPoint 00000001@ removed from call 1
18:33:22.551|.\MediaServer.cpp(744)|Trace5||??:references to EndPoint 00000002@ were removed
18:33:22.691|.\MediaServer.cpp(744)|Trace5||??:references to EndPoint 00000001@ were removed
18:33:22.691|.\MSEndPoint.cpp(532)|Trace5||??:EndPoint 00000001@ destroyed
18:33:22.691|.\RTPReceiver.cpp(127)|Trace5||??:Endpoint for socket 712 is not found!
18:33:22.691|.\MediaServer.cpp(1063)|Trace5||??:references to call 1 were removed
18:33:22.691|.\MSCallConf.cpp(33)|Trace5||??:Call: 1 destroyed
