Pressing "Line 1" button when phone is ringing
Discussion in 'Windows' started by softvision, May 13, 2008.
  1. softvision
    May 13, 2008
    I have a strange behavior of the VoIP client. I have setup a test environment with the phone system and two voip clients. Everything is connected and working fine.
    When I now start a call from the first client the second client is ringing. Then I hit the "Line 1" button on the first client. The second clients continous ringing, but the first client has lost the call ("on hook" message in the window). I can't get back the call. When I then pickup the call on the second client, the phone call is established bewtween both clients.
    Is this the normal behavior when I press the "Line 1" button?
    Bernd
