If everone need this, a customer whanted this but without the presence control, here is my little Script:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using TCX.Configuration;
using TCX.PBXAPI;
using System.Threading;
namespace OMSamples.Samples
[SampleCode("fix_dn_to_queues")]
[SampleParam("arg1", "Specifies extension number")]
[SampleDescription("Shows how to drop calls on specific extension using Call Control API")]
class fix_dn_to_queues : ISample
public void Run(params string[] args)
PhoneSystem ps = PhoneSystem.Root;
string[] extensions = new string[] { "" };
string queue = args[2];
int arg_number = 0;
foreach (string arg in args)
arg_number = arg_number + 1;
if (arg_number == 2)
extensions = arg.Split(',');
if (arg_number == 3)
queue = arg;
while (true)
foreach (string extension in extensions)
foreach (DN dn in PhoneSystem.Root.GetDN())
if (extension.Equals(dn.Number))
string logged_in_queues = dn.GetPropertyValue("LOGGED_IN_QUEUES");
Console.WriteLine("Loggedindd " + dn.Number + " " + logged_in_queues);
dn.SetProperty("LOGGED_IN_QUEUES", queue);
Extension ext = ps.GetDNByNumber(extension) as Extension;
ext.QueueStatus = QueueStatusType.LoggedIn;
ext.Save();
dn.Save();
Thread.Sleep(5000);
Implement this into the omsamples example and run omsamples with the follow paramenter:
fix_dn_to_queues "001,002",003" "100"
001 - 003 = Extension Number
100 = Queue
In this Script the User will be only Logged in to Queue, he can set another presence to logout. When this is needed also this is a little work.The user can logout from queue but the Script will he login back.
