Previous version
Discussion in 'Windows' started by matthijsolislagers, Mar 13, 2008.
  1. matthijsolislagers
    matthijsolislagers New Member
    140
    Can I download the previous ( 5.0.4034 ) version of the VOIP client anywhere. I need it becouse the latest build doesn't run on Terminal Server.
    Thanks.
  2. darrellchapman
    Nov 26, 2007
    268
    matthijsolislagers,
    I'm sorry this is not an answer to your post but can you please explain advantages to running the client in TS? I mean, do you have multiple users logging in to a single TS and running applications, or are you talking about individual connections to Remote Desktop? I'm interested to know how this is working out.
    Also, what's the audio delivery like in TS? In my experience audio has a lot of quality and latency problems in TS. Are you not having any trouble?
    Thanks so much for your advice.
  3. matthijsolislagers
    140
    All users are working on a terminal server. There are no desktops, just thin clients. This makes management and remote working easier.
    I'm using the VOIP client in desk phone mode. Wich allows users to dial directly from Outlook. Audio goes via the desk phone. There are indead lot's of audio quality problems in TS. I don't think you could make a phone call that way.
    The latest VOIP client build allows only one instance running. The second instance on a terminal server shuts down immidiatly. Thats why I would like to return to the previous version for now.
  4. darrellchapman
    Nov 26, 2007
    268
    Thanks for the info matthijsolislagers. I appreciate you taking the time to explain that to me. That's very interesting.
  5. matthijsolislagers
    140
  6. mandev
    Feb 27, 2008
    35
    He is right but why would you want it how do you use a remote Microphone with TS? What about the load on the server of say 10 phone streams?
