Previous Versions for Download
Discussion in 'Windows' started by neilcooley, Oct 15, 2015.
  1. neilcooley
    Oct 15, 2015
    Where can I find previous versions for 3CX Soft Phone to download?
    The new release of 3CX soft phone (for v14) wont work with our current server installed software.
    Neil
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Yes, if you installed the latest 3CXPhone you need to also update your 3CX PBX Server.
    We made heavy improvements and this is required.
    You could do the following if you want install 12.5 with clean accounts, provision your client and perform update. It will use Release Version of 3CX Phone.
  3. leejor
    10,861
    302
    Version 12 is available here...
    http://www.3cx.com/downloads/3CXPhoneforwindows12.msi
    It would be helpful if 3CX left all old versions of software, available for download, for those that forgot to archive them.
