Pri cards
Discussion in '3CX Phone System - General' started by bblokey, May 12, 2008.
  1. bblokey
    Apr 15, 2008
    57
    Does anyone have a list of pri cards that 3CX supports?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Most of us are using Patton SN4960 for PRI line. 3CX should be not support any internal PCI PRI card.
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,887
    190
    You might want to check the FAQs:
    http://www.3cx.com/support/
    You will also find a list of supported gateways. PRI cards are not supported.
  4. Nick Galea
    Jun 6, 2006
    1,887
    190
    A VOIP gateway doesnt really count as a separate box in my opinion. Secondly, its not necessary to dedicate a box to 3CX - it can run on an existing server or as a VM or Hypervisor session. Thanks to the gateway, that takes over the digital to analog processing, 3Cx can run efficiently and very scalable. This solution is much more manageable than a 'black box' appliance.
