PRI/T1 Gateway
Discussion in '3CX Phone System - General' started by dmarte, Feb 9, 2009.
  1. dmarte
    Feb 9, 2009
    I am looking into installing 3CX in my office here in TX, US. We are currently on an Intertel PBX hooked to a T-1. I want to get a good gateway for this 3CX install but do not seem to make my mind. Any recomendations??? The Intertel is coming down not interface at all is needed. It will be a pure 3CX VoIP.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,926
    243
    I recommend the Patton T1 gateway...
  3. dmarte
    Feb 9, 2009
    What model in specific?
  4. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    Have a look at the datasheet at http://www.patton.com/datasheet/SN4960_datasheet.pdf . There are the various model numbers based on channels required.
  5. dmarte
    Feb 9, 2009
    Will all the necessary configurations will be generated for this particular model??
  6. William400
    Aug 21, 2006
    1,005
    Yes, the configs for the 4960 are all generated for 3CX.
    If you plan to use a fractional e1/t1 then you should contact support as minor tweaking will be required to set the channels that are active / set for voice.
