PRI VoIP Gateway
snail945
Is there a tested a recommended PRI VoIP gateway avaiable for use with the 3CX system?
Happy New Year!
I'm using Patton Smartnode 4960. It can be found at supported list. Once set it up, you will be no need to touch it. Therefore, you may be lost your configuration skill for this gateway as well :wink:
PRI gateway
We have a Cisco 1811 with single PRI interface, and it has been working very well. Did some initial echo cancellation tweaking but since then has not needed to be touched.
Mark
PRI gateway
thanks gents. helpful info.
Others, feel free to post recommendations, successes.
best. --byron
Get 3CX - Absolutely Free!
3CX
