Priority of the Mediaserver - Choppy Voice - Eliminated?
Discussion in '3CX Phone System - General' started by silentfun, Nov 21, 2007.
  1. silentfun
    silentfun Member
    Dec 11, 2006
    364
    i have never got this issue possible a result of a special combination of settings?
  2. paul@pcjen.co.uk
    Oct 8, 2007
    8
    Priority of the media server
    Hi Guys
    How do you set the priority of the Media Server please
    Cheers
    Confused
  3. Urbok
    Urbok New Member
    Jul 14, 2007
    120
    i've tried to change the priority of mediaserver cpu usage in the past (tried from task manager)
    but an error comes when I try to set an higher priority.
    a facility to change the priority within 3cx well be appreciated.
