Privacy issue in 3CX hosted: Block users on a different instance to see information of users on othe
Discussion in 'Ideas' started by Chib@voip, Apr 18, 2016.
  1. Chib@voip
    Feb 25, 2016
    21
    3CX v14 Hosted has this option: Generate Support Info enabled for all users on all instances.
    Generate Support Info shows information for all instances on the server, not just the one you are logged into.
    This means that a user on instance 1 can download this support info and see names and extension info of users on instance 2,3,4 etc.
    We do not want to have our customers on instance 1 seeing the information of users on other instances.
    Things that can be seen of users on other instances:
    1.Full Name (if filled in),
    2. their Extension number,
    3. their local IP address,
    4. WAN IP address,
    5. Phone type and Firmware,
    6. SIP port,
    7. Hostname
    and probably more if you dig a little deeper.
    This kind of information should never be revealed to any other users on a different instance.
    I`m afraid that this can even become a legal issue in certain countries.
    We would like to see this option "Generate Support Info" being disabled by default on all instances, or at the least being made optional by the server admins.
  2. Chib@voip
    Feb 25, 2016
    21
    Because I think this is a pretty serious issue, please UPVOTE this idea so this things will get added/changed asap.
  3. Anonymous
    Anonymous Guest
    I found extension numbers and IPs for other Instances in a single the Extralogging\tcxSystemEvents_**NumberString**.CSV file. This was evening using a limited account to look at the config page. I agree, this is troubling.
  4. Chib@voip
    Feb 25, 2016
    21
    Privacy of users is at stake.
    This could get the 3CX hosting provider as well as 3cx in trouble.
  5. Chib@voip
    Feb 25, 2016
    21
    Bump. I hope this security feature (disabling Generate Support Info) is going to be implemented in V15. Anybody knows?
    I don`t think we should rely on votes to take this privacy "idea" seriously.
  6. Chib@voip
    Feb 25, 2016
    21
    Update:
    I am now testing on a V15 (virtual) machine and when I select Generate Support info, the admins are getting an e-mail notification with a downloadable Zip file. Not the user!
    3CX V15 has implemented this idea.. thanks!
  7. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,887
    190
    The MULTI TENANT version has been retired. The best way to host is now using a virtual dedicated instance of 3CX
  8. Chib@voip
    Feb 25, 2016
    21
    Thats probably why then. Thanks for clarifying
