Private IP address in 'Contact' field using STUN
Discussion in '3CX Phone System - General' started by antler, May 19, 2011.
  1. antler
    May 8, 2011
    40
    Hallo forum,
    I have searched for a hint of a fix for this problem @ 2 weeks now and am going absolutely nowhere, I am sure someone, somewhere has the answer, whether it be a config issue or a BUG, I have to ask.
    I do not currently have a fixed IP address hence I am using STUN. On fire up of the PBX, the STUN message [CM506001] is sent and I recieve the correct response [CM506002].
    I have, in my VoIP provider settings under 'Advanced > Registration Settings > Which IP to use in 'Contact' field for registration > 'External (STUN resolved).
    Then why
    1) does my registration message to my actual VoIP provider [1+1] contain my private IP address [Cause: 403 Keine RFC1918-IPs erlaubt] and
    2) why are there two registration attempts milliseconds later for the failed registration even though the failed point states 'in 5 minutes' plus a second registration for the sucessfull registration to another route?
    14:42:18.265 [CM504004]: Registration succeeded for: 10001@fb
    14:42:18.171 [CM504007]: Next attempt to register 10000@1+1 is scheduled in 5 minute
    14:42:18.140 [CM504005]: Registration failed for: 10000@1+1; Cause: 403 Keine RFC1918-IPs erlaubt; from IP:212.227.67.131:5060
    14:42:18.093 [CM504003]: Sent registration request for 10001@fb
    14:42:18.078 [CM504003]: Sent registration request for 10000@1+1
    14:42:18.015 IP(s) added:[192.168.178.28]
    14:42:09.375 [CM504004]: Registration succeeded for: 10001@fb
    14:42:09.218 [CM504007]: Next attempt to register 10000@1+1 is scheduled in 5 minute
    14:42:09.171 [CM504005]: Registration failed for: 10000@1+1; Cause: 403 Keine RFC1918-IPs erlaubt; from IP:212.227.67.131:5060
    14:42:09.062 [CM504003]: Sent registration request for 10001@fb
    14:42:08.937 [CM504003]: Sent registration request for 10000@1+1
    14:42:08.796 [CM506002]: Resolved SIP external IP:port (84.59.164.155:5066) on Transport 192.168.178.28:5066
    14:42:08.718 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 212.227.67.194:3478 over Transport 192.168.178.28:5066
    14:42:08.468 Transport [ V4 192.168.178.28:5066 UDP target domain=unspecified mFlowKey=780 ] is joined to SIP multicast group
    14:42:07.953 Failed to obtain short path name for [C:\Documents and Settings\All Users\Application Data\3CX\Bin\Cert]
    14:42:07.953 [CM501006]: Default Local IP address: [192.168.178.28]
    14:42:07.937 [CM501007]: *** Started Calls Controller thread ***
    14:42:07.937 [CM501002]: Version: 10.0.19079.0
    14:42:07.937 [CM501001]: Start 3CX PhoneSystem Call Manager
    14:42:07.265 [EC200001]: Configuration server is connected: application:[myPCname]:5485/DBProvider local:127.0.0.1:2975 remote:127.0.0.1:5485
    14:42:07.171 [CM501009]: License Info: Loaded Succeeded
    When I select the 'Specified IP' under 'Advanced > Registration Settings > Which IP to use in 'Contact' field for registration >, the registration is 100% sucessfull.
    Note that I am able to sucessfully connect direct to my provider with a 3cx softphone v6 running on the same PC that I have the 3cx server.
    I have also attached a comprehenisve wireshark trace
    Any help would be appreciated and thanks in advance.
    Antler
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Can you post screen shot of the following screen?
    >> Settings > Network Settings (Stun server)
  3. antler
    May 8, 2011
    40
    Hallo David,
    Thank you very much for responding and here is a file attachment of the screen shot you have asked for...[unsure as to how to place the actual screenshot within this page!]
    Gruß
    Antler.
  4. davidbenwell
    Apr 27, 2010
    704
    click submit a support ticket under my name and use the tool to upload the picture.
  5. antler
    May 8, 2011
    40
    Hallo Dave,
    Ticket with STUN config attachment raised, Ticket ID: JQ4QZ31B8H
    Gruß
    Antler.
  6. startelecom
    Mar 12, 2011
    17
    Has this been addressed?
