Private / Trusted SIP trunks
Discussion in 'Ideas' started by datamerge, Nov 26, 2015.
  1. datamerge
    datamerge New Member
    Nov 19, 2014
    194
    28
    There are many instances where a 3CX may need to trunk to a peer system in a trusted environment. E.G. Trunking between two friendly companies, or trunking between 3CX and another different system within a company.
    I would like an option to enable a SIP trunk as internal/trusted, where implicitly all outbound calls present the internal caller ID and inbound calls are directed into the internal dial plan. This option would simply be added to the existing trunk types so they are validated the same way they are now. I.E. register, or source fields/IP address
