Private VLANs (PVLAN, Port Isolation) & 3CX
Discussion in '3CX Phone System - General' started by poynter.net, Mar 16, 2018.
  1. poynter.net
    Aug 26, 2009
    36
    5
    We are implementing a network with port isolation for the PC Clients.
    Do we need to leave the ports that have phones connected as open (unprotected)?
    This should then allow each phone to transmit to every other device for local phone-to-phone calls. As well as respond to multicast requests for provisioning.
    I'm guessing if we protected the phone ports, then the PBX would need to deliver audio as that would be on an unprotected port.
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,577
    209
    Hi poynter.net,
    What sort of kit are you using for your network? Router/Firewall & Switching?
    The main concern you will always have with VLAN's with 3CX is getting voice and data to talk to one another whilst keeping segregated.
    If you are using 3CX phone on you data network in CTI mode with a supported phone, data and voice will need to be routed via the firewall.
    3CX now supports VLAN tagging and other port based parameters - see under extensions & Provisioning, but you must have a supported phone model.
    https://www.3cx.com/sip-phones/vlan-configuration/
