PROBLE WITH EXTERNAL
Discussion in '3CX Phone System - General' started by kirimis, Nov 13, 2007.
  1. kirimis
    Oct 16, 2007
    43
    i HAVE PROBLEM WITH EXTERNAL EXTENTIONS
    When i cal the i can hear the but they cannot, if they reboot the sip phone the it is ok for a while, after two calls the same thing goes on. ports are ok and i have also stun server on remote set as stun.3cx.com.
    Can somebody help?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please provide more details for your problem. Such as 3CX version ? Console log.
  3. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    These types of problem are usually related to STUN settings or NAT not being enabled at the remote end and so when the media server tries to setup a audio channel it fails. With a snippet of your status log (in debug mode) that covers one of these calls we can give you a better idea as to whats happening.
