Problem again with version 3.1.2434.0
Discussion in '3CX Phone System - General' started by jrme1, Aug 30, 2007.
  1. jrme1
    Jun 14, 2007
    26
    Hi, do you remenber when i upgrade to version 3.1.2434.0 as i posted in: http://www.3cx.com/forums/viewtopic.php?t=2008&highlight=
    Well, now after 3 weeks, again encounter this problem . This is my log:
    17:28:28.865 CallConf::Rejected [CM103005] Call(1) is rejected: This line disallows incoming calls
    17:28:28.865 Endpoint::findSource [CM010001] Line configuration does not allow identification of the source of this call. Check Advanced Options for Gateways and Providers and match a field to a correct value from the following: Contact IP: '62.205.73.166'; From: '10000'; To: '10001'; Rline: '10001'; Contact: '10000'
    10000 and 10001 are internally extensions. i don't understan why the log say check "Gateway and Providers..."
    Why happen this???
    My server is Windows 2003, and only is used for 3cx, with 100Gb hard drive and 1Gb Ram and direct connection to internet.
    I triying to reinstall, but one more time i need provisioning the server manually!!, because any backup file do it the same after install. :x :x :x
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Did this problem appear right after upgrade or everything was working and problem appeared after some time?
  3. jrme1
    Jun 14, 2007
    26
    Re.
    The first time was after upgrade to that version. But now was also after about two weeks.
    All was good, and one day stop working, all the extension sound like busy and the log show that message.
    I solved, installing a new fresh 3cx version and provisioning manually all the data (extensions and provider), because the backup file backup also the error.
    i hope you solve this for future release...
    thanks :?
