problem between GXP1405 and 3cx
Discussion in 'Windows' started by juniorloureiro, May 5, 2014.
  1. juniorloureiro
    Nov 5, 2013
    Hello Guys,
    I have 15 Alcatel Lucent ip Phone 8 with my 3CX v12 (8sc) and recently I bought 2 Grandstream GXP-1405, one worked property.
    The other one has a weird problem, when it is plugged and powered up the others phone simply unregister and stop working, keep those on infinity loop.
    I changed the problematic one for a new one, and for my surprise the new one does the same problem.
    Someone experienced some near of that?
  2. roland_3CX
    roland_3CX Support Team
    Mar 28, 2014
    131
    7
    Hello Junior,
    Please consult the link below regarding Grandstream IP Phones.
    http://www.3cx.com/sip-phones/grandstream-gxp1450/
  3. juniorloureiro
    Nov 5, 2013
    Hello Roland.
    Problem solved.
    The PC cable was at LAN socket and vice-versa.
    That was the problem here.
    Thanks for your help.
    Best regards.
    Junior
  4. roland_3CX
    Mar 28, 2014
    131
    7
    Hello Junior,
    Thank you for the updated. Glad the issue is resolved.
