Problem - Call Forward to External Number
Discussion in '3CX Phone System - General' started by nathan@refinedit, Nov 9, 2015.
  1. nathan@refinedit
    Nov 9, 2015
    Hi Team,
    When trying to enable call forwarding to an external mobile number, I receive the following notification
    09-Nov-2015 08:24:28.105 [Flow] Target endpoint for XXXXXXXXXX can not be built!
    The number is callable directly from an ext but calls can not be forward. I am assuming it is something in the outbound rules but I have no restrictions set there.
    Ideas?
    Nathan
    10,368
    228
    If the number can be dialled by the extension, and you are using exactly the same digits in the forwarding rule, then it's probably not an outbound rule issue.
    Are there any restrictions, in place, for that extension, in the extension settings?
    Is there an available trunk for the call to forward on?
    Is it just this one extension having problems? Are others able to forward successfully?
    Have a look at the verbose logs, it may give you some additional information as to why it's not going through.
  3. nathan@refinedit
    Nov 9, 2015
    Thanks for the reply. Turns out it was an outbound rule.
    I had set the ext range 100-200 so ofcourse it wouldnt allow a call from a number on in that range.
    I would say now I need to create a rule to allow outbound calls from 04* to allow it to divert to mobile
