Problem configuring remote extensions
Discussion in '3CX Phone System - General' started by jbarrios, May 15, 2008.
  1. jbarrios
    May 14, 2008
    I just downloaded the 3CX software free edition for testing and I tried to configure one remote extension in a gateway (3CX softphone works with tunneling only). The remote extension authenticates correctly, it can receive and make calls but only the destination can hear me, I tried openning all ports in both sides but the problem continues.
    If somebody know how to solve this issue please send me some hints to try over here.
    Thank you,
    Jose
  2. wisecomputers
    wisecomputers New Member
    Apr 24, 2008
    126
    I had the same issue at one time. It is the way your client is set up. I'm not 100% sure, but I think all I did to fix it was change my internal ip to my computer ip, instead of my wan ip. You have to remember this is a tunnel like a vpn, so it uses you computers subnet ip, and not the wan ip given by your provider.
    Dan
