problem did
Discussion in '3CX Phone System - General' started by clavaud, May 9, 2008.
  1. clavaud
    Jun 27, 2007
    25
    with version 5.0.36.48.0 numbers did not work.
    Etat server during a call did 0870
    11:19:08.296 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: INVITE 0870@12.150.0.4 tid=1b4903eb306b6bac.1 cseq=INVITE contact=1001@17.150.0.50:5060 / 317 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    Extract for programming
    - <row>
    <field name="idgateway">49</field>
    <field name="name">telecom</field>
    <field name="model">GenericVoIPProvider.pv.xml</field>
    <field name="host">sip.serveurvoip.com</field>
    <field name="vpnip" />
    <field name="port">5060</field>
    <field name="maxlines">0</field>
    <field name="outcid" />
    <field name="invitewithreplace">1</field>
    <field name="useipincontact">0</field>
    <field name="calleridin">0</field>
    <field name="linetype">0</field>
    <field name="lineidin">0</field>
    <field name="callednumberin">0</field>
    <field name="destnumberin">1</field>
    <field name="destnumberin_to">1</field>
    <field name="destnumberin_reqlineuri">1</field>
    <field name="destnumberin_rpid_called">0</field>
    <field name="isinternal">0</field>
    <field name="isbindtoms">1</field>
    <field name="issupportreinvite">0</field>
    <field name="issupportreplaces">0</field>
    <field name="requireauthfor">4</field>
    <field name="ipincontactreg">1</field>
    <field name="specregip" />
    <field name="usecontactfield">0</field>
    <field name="gatewaytype">0</field>
    <field name="usevpn">0</field>
    <field name="mathstrategy">1</field>
    <field name="source1_fkidgwpar" />
    <field name="source1_fkidgwparvalue" />
    <field name="source1_customvalue" />
    <field name="source2_fkidgwpar" />
    <field name="source2_fkidgwparvalue" />
    <field name="source2_customvalue" />
    <field name="source3_fkidgwpar" />
    <field name="source3_fkidgwparvalue" />
    <field name="source3_customvalue" />
    <field name="toneset" />
    </row>
    </table>
    <table name="iprange2gateway" />
    - <table name="provider">
    - <row>
    <field name="fkidgateway">49</field>
    <field name="authid" />
    <field name="authpswd" />
    <field name="timebetweenreg">3600</field>
    <field name="codec" />
    <field name="stunhost" />
    <field name="stunport">0</field>
    <field name="registrarhost">sip.serveurvoip.com</field>
    <field name="registrarport">5060</field>
    - <table name="inboundruledid">
    - <row>
    <field name="idinboundruledid">79</field>
    <field name="inputmask">0870</field>
    <field name="overrideincoming">1</field>
    <field name="fkiddnrouteto">4</field>
    <field name="fkiddnroutetoooh">4</field>
    <field name="routetotype">0</field>
    <field name="routetoout" />
    <field name="routetooohtype">0</field>
    <field name="routetooohout" />
    <field name="faxbehaviour">1</field>
    <field name="fkidfaxdn">2</field>
    </row>
    - <row>
    <field name="idexternalline">50</field>
    <field name="fkidinboundrule">76</field>
    <field name="fkiddn">55</field>
    <field name="authid">0810</field>
    <field name="authpswd">0810</field>
    <field name="linenumber">0810</field>
    <field name="direction">3</field>
    <field name="maxcalls">10</field>
    </row
